Open Arduino
  • Open Arduino
Open Arduino
Blog Cycloboat
Join Open Arduino to participate - click to join for free!
  • Author Author: Molham
  • Date Created: 29 May 2018 4:21 PM Date Created
  • Views 3386 views
  • Likes 9 likes
  • Comments 9 comments
  • arduino_classic
  • arduinos
  • Arduino Day
  • openarduinoch
  • project14
Cycloboat
Molham
Molham
29 May 2018
Cycloboat is a recycled boat robot that uses plastic bottles to float on water.
It can detect objects and avoid it using ultrasonic.
I will be posting more videos with some more description later.
1. Right Angle Gear Motor: voltage is 4.5-6V with a no load current of 190mA, output shaft is 9mm long and the gearbox ratio is 48:1 with a wheel speed of 140 RPM (unloaded)
2. Dual Ball Bearing Hub
3. Arduino Uno as a brain and control system of Cycloboat
4. L298N Motor Drive Controller Board Module Dual H Bridge.
5. Ultrasonic Module
6. Batteries 4 x 1.5v each total of 6v dc
7. Fan recycled from old fan
8. Sealed wood box.
9. Aluminum Pole and mounting channels hub.
10. Recycled plastic bottles X 3.
Figure (1): Right Angle Gear Motor
Figure (2): Dual Ball Bearing Hub
Figure (3): ARDUINO UNO MCU ATMEGA328p
Figure (4): L298N Motor Drive Controller Board Module Dual H Bridge.
Figure (5): Ultrasonic Module.
Figure (7): Fan recycled from old fan.
Full System
Code:
$regfile = "m328pdef.dat"
'$regfile = "m16def.dat"
$crystal = 8000000
Config Pind.2 = Output : Dc1 Alias Portd.2 : Reset Dc1
Config Pind.1 = Output : Dc2 Alias Portd.1 : Reset Dc2
Config Pind.3 = Input
Config Portd.4 = Output
Portd.3 = 0
Portd.4 = 0
Dim Distance As Word , W As Word , I As Byte
'-----------------------[LCD Configurations]
Distance = 0
Cls
Do
Pulseout Portd , 4 , 20                                     'Min. 10us pulse
'Waitms 100 'meant for testing error
Pulsein W , Pind , 3 , 1                                    'read distance
Incr I
If Err = 0 Then
W = W * 10                                                  'calcullate to
W = W / 58                                                  ' centimeters
'W = W / 6 ' milimeters
Distance = W
Gosub Move_backward : Waitms 200
Else
Distance = 0
Gosub Move_forward : Waitms 200
End If
Waitms 200
Loop
Return
'--->[Move Renbot with 4 motors forward]
Move_forward:
   Set Dc1 : Reset Dc2
   Waitms 100
Return
'--->[Move Renbot with 4 motors backward ]
Move_backward:
   Reset Dc1 : Set Dc2 :
   Waitms 100
Return
First test:
  • 14rhb
    14rhb over 8 years ago +2
    Hi Molham, A great idea. I was particularly taken though with those neat pre-drilled brackets, and when I searched for 'dual ball bearing hub' I found a site that makes them....they look really useful…
  • tariq.ahmad
    tariq.ahmad over 8 years ago +2
    Very cool!
    DAB over 8 years ago +2
    Your approach has some interesting possibilities. DAB
  • tariq.ahmad
    Very cool!
  • Molham
    Molham over 8 years ago in reply to tariq.ahmad
    Thank you
  • Molham
    Thank you
