Open Arduino
  • Open Arduino
Open Arduino
Blog Robot balances and translates on a ball using Arduino.
Join Open Arduino to participate - click to join for free!
  • Author Author: thachdovan
  • Date Created: 20 Apr 2018 2:21 PM Date Created
  • Views 5833 views
  • Likes 12 likes
  • Comments 25 comments
  • openarduinoch
thachdovan
thachdovan
20 Apr 2018
Open Arduino
Enter Your Project for a chance to win a grand prize for the most innovative use of Arduino or a $200 shopping cart! The Birthday Special: Arduino Projects for Arduino Day!
Project14 Home
Monthly Themes
Monthly Theme Poll
General Description
A robot that can balance and translate on a spherical ball is developed. Its primary purpose is to focus on the high mobility in a narrow space. It can be applied in many applications such as home automation, indoor services, ...
The complicated ball robot system with large size is implemented by using two Arduino Due boards. These boards and its shield are set on the top of the robot body as the following picture:
Body
(Hardware structure of the robot system)
The robot collects data from a 9DOF Xsens IMU which possess the high accuracy of measurements. By using this device we can obtain the lean angles of the robot. Two Arduino boards and its shield is used to sense the signal from the sensor and generate control pulses for 200W AC Servo Motors. The translation and balancing of the robot are governed by the combination motions of the three omnidirectional wheels on a spherical ball.
The demonstration aims to show operations of the robot, it can be controlled by using a Joystick as well as be able to recover to the initial position even though several large forces are pushed to the robot body.
https://www.youtube.com/watch?v=reyCgdOuSWo
  • thachdovan
    thachdovan over 8 years ago in reply to jw0752 +5
    Dear Mr. John and Mr. Jan, thanks for your comments. For each kind of robot, they have their own advantages and drawbacks. In this kind of robot, the high mobility of the robot is focused. The robot can…
  • thachdovan
    thachdovan over 8 years ago in reply to bradybowers +4
    Thanks for your question! Any kind of robots or even a human, they obviously would be fallen if a high force is applied within a short time. However, we can improve the physical structure and control algorithms…
    Jan Cumps over 8 years ago in reply to thachdovan +4
    thachdovan wrote: Hi Enrico, I wrote my own controller and software to control it. Thachdovan, That's the design we're interested in. What you've made, how it fits together and how it works.
  • three-phase
    three-phase over 8 years ago
    Very interesting project. Looks well built, would be nice for you to expand on the engineering involved a bit.
    Kind regards
  • thachdovan
    thachdovan over 8 years ago in reply to three-phase
    Thank you, I just updated. Please rate for my project image
  • thachdovan
    @tachdovan, Check the 'List-the-steps' section of the main document for Open Arduino .
    It explains the documentation criteria. You may get a better score if you explain to the community how to reproduce and program the design.
    Good luck!
