Proving Science
  • Proving Science
Proving Science
Blog TempMeter#2 : Improved Accuracy by Using a Laser Poiter
Join Proving Science to participate - click to join for free!
  • Author Author: dubbie
  • Date Created: 19 Aug 2020 4:06 PM Date Created
  • Views 2699 views
  • Comments 10 comments
  • provingsciencech
  • temperature meter
  • mirror
dubbie
dubbie
19 Aug 2020
Proving Science
Project14 Home
Monthly Themes
Monthly Theme Poll
Although my original Tempmeter (TempMeter : Measuring Temperature with a Brass Rod  ) does successfully measure temperature it requires quite a large temperature change to create a visible alteration to the indicator. It was suggested that by Dave Ingles beacon_dave and John Wiltrout jw0752 that a mirror could be used with a laser to increase  the sensitivity, so I thought I would try it out.
I 3D printed a small holder for some circular mirror pieces that I happened to have, putting two identical mirrors either side of the 1 mm rod used to make the pointer turn. See below. I used two mirrors to balance the unit and avoid any turning torgue problems.
It is essentially just a small washer shape with an indent each side to hold the mirrors and a 1 mm hole through the side.
I used a small laser pointer (it's a cat's toy!) Bluetac'ed onto the side of the piece of reconstituted marble stone and adjusted to shine onto the centre of the small mirrors. The complete working system is shown below in the video.
After trying the ceiling as the display I thought I would try using a wall instead to see if the movement was more visible and it was.
I also noticed that the laser dot seemed to be sensitive to vibration as well. It seemed to me that if I tapped the stone base that the laser dot did jiggle slightly. It might have just been my eyes but it would make sense that if you make the system sensitive enough then it will measure vibration. Maybe it could be a combined temperature and vibration measuring meter!
Dubbie
  • neilk
    neilk over 6 years ago +2
    Nice one. Takes me back to the school physics lab in the 1960s, using a mirror galvanometer and a light source projecting on to a scale on the wall. Neil
    beacon_dave over 6 years ago +2
    ...now then, two more mirrors, a second laser pointer and you could make a vector laser projector to project the scale onto the wall/ceiling... It's looking good though ! Were you able to find and use…
    jw0752 over 6 years ago +2
    Hi Dubbie, Very well done. It was fun to see the lazer dot run across the ceiling. Even the slant of the ceiling served to amplify the effect. John
  • neilk
    Nice one.
    Neil
  • neilk
    Nice one.
    Neil
    dubbie over 6 years ago in reply to neilk
    Neil,
    I must admit, once I had made the mirror unit that was exactly my thought as well. It also made me think .... Ummmm - I wonder what else I could do with this?
    Dubbie
