Proving Science
  • Proving Science
Proving Science
Blog Voltmeter 4*Reading
Join Proving Science to participate - click to join for free!
  • Author Author: harjinagi
  • Date Created: 31 Jul 2020 9:29 PM Date Created
  • Views 1572 views
  • provingsciencech
Voltmeter 4*Reading
harjinagi
harjinagi
31 Jul 2020
Proving Science
Project14 Home
Monthly Themes
Monthly Theme Poll
I made a dc voltmeter which displays four different reading simultaneously on 16*2 LCD screen via Arduino nano and voltage divider circuit.The monitoring display consist of 4 different parameters i.e V1,V2,V3,V4. Each parameter can measure up to 12 volts.
In this vedio I connected solar panel,5 volt battery and two*9 volts battery.
The code and schemeati diagram is given here
code:
    dubbie over 6 years ago
    Harji,
    I don't think we can see the code from the Element14 site. Also, have you thought about using an analogue switch to change the resistor ratios? You then might be ble to make an auto-ranging digital voltmeter.
    Dubbie
    Harji,
    Dubbie
