Remote Monitoring & Control
  • Remote Monitoring & Control
Blog Smarthab: Remote Sensing and Control .ii   Environmental Controls
Join Remote Monitoring & Control to participate - click to join for free!
  • Author Author: phoenixcomm
  • Date Created: 1 Jul 2019 1:37 PM Date Created
  • Views 1023 views
  • dehumidifier
  • remotemonitoringcontrolch
  • humidifier
  • air quality
  • control
  • temperature
  • iot
  • sensor
phoenixcomm
phoenixcomm
1 Jul 2019
Ok, lets start what we mean by environmental control and what is it. Environmental control is what temperature, humidity, air quality.  Lets take theses one at a time so I don't loose you.
  1. Temperature:  This is the current temperature of you room or house. This can also be adjusted. Heating system can be Forced Air, Hot Water and Radiators, In Floor Radiant System (ether, electric or water). While air conditioning is normally forest air cooled by Freon, cold or chilled water systems can be used as well.
  2. Humidity: This is the current humidity of you room or house. The  humidity is controlled by two units.
    1. Dehumidifier, a device which is basically a small air conditioner.
    2. Humidifier, a device which inserts water vapor into a forced air duct.
  3. Air Quality: This is comprised of several items.
    Roomx per hr
    Basement3-4
    Bathroom6-7
    Bedroom5-6
    Family room6-7
    Kitchen7-8
    Laundry8-9
    • How many times the air in the house is turned over every hour.
      Air Changes / per hour = ( 300 CFM x 60 ) / ( 15'x20'x8' ) or about 7.5/per hr.
    • Air filter performance. This is accomplished by a mass-flow sensor which can be found in most cars. as the dirtier the filter the less airflow you will have.
    • How much fresh air are you letting in the house by a Air-to Air Heat Exchanger. This is a must have in a tight house.
part i
part iii
