Sensors Projects
  • Sensors Projects
Sensors Projects
Forum which sensor to be used to detect a transparent plastic container
Join Sensors Projects to participate - click to join for free!
  • Subscribers 13 subscribers
  • Views 1964 views
  • proxmity sensor
pritesh
pritesh over 5 years ago
Hi, I need to find an industrial grade proximity sensor which can sense the presence of an transparent acrylic box in 5-10mm sensing range.
    dougw over 5 years ago +3
    There are industrial grade ultrasonic sensors that should be able to handle this task.
  • fmilburn
    fmilburn over 5 years ago +3
    There is an Omron optical sensor that works with transparent material. I demonstrate it here here with glass and plastic: https://www.element14.com/community/roadTestReviews/3403/l/omron-sensor-evaluation…
  • fmilburn
    There is an Omron optical sensor that works with transparent material. I demonstrate it here here with glass and plastic: https://www.element14.com/community/roadTestReviews/3403/l/omron-sensor-evaluation-board-2jcie-ev-review
    There is a 2-10mm version, I tested the version that works from 10-55mm. Page down to the bottom and look for the  B5W-LB2101-1
