Solar Power Devices
  • Solar Power Devices
Solar Power Devices
Blog Solar SPEC - Completed Assembly
Join Solar Power Devices to participate - click to join for free!
  • Author Author: ralphjy
  • Date Created: 14 Sep 2018 4:40 AM Date Created
  • Views 1046 views
  • solar panel
  • iot_projects
  • solarpwrdevicesch
  • iot design
ralphjy
ralphjy
14 Sep 2018
I've completed the build of my SPEC unit.
1) Added terminal block for external temperature sensor
2) Added 18B20 temperature probe
3) Added power switch
4) Added power indicator LED
5) Adapted Solar Cell wiring to micro USB for 8266 Thing power input (spliced the end of a micro USB charging cable)
6) Added cover gasket (temporarily using rope caulk until I can cut a neoprene gasket)
I still need to update the program to use the 18B20 temperature sensor rather than the DHT22.  And I need to change the offset in the irradiance reading.  I'm not sure what I will do for a finale video as this thing doesn't have any moving parts.
    genebren over 8 years ago +1
    Looking good! That is a pretty nice case that you created. Keep up the good work! Gene
    Gene
    Gene
