Spring Clean!
  • Spring Clean!
Spring Clean!
Forum Major RS2020L
  • News and Projects
Join Spring Clean! to participate - click to join for free!
  • Replies 8 replies
  • Subscribers 102 subscribers
  • Views 608 views
  • Spring Clean 2026
  • radio repair
Major RS2020L
strb
strb 7 months ago
Hi everyone,
as part of this spring clean competition I'm trying to repair a Major RS2020L radio given to me last year. I think I've narrowed down the problem to the output power stage, but here my knowledge ends. All transistors appear to be in good shape (I've desoldered and checked them one by one off board with a multimeter in diode mode). No apparent sign of leaky caps. No exceeding current drawn from the supply, fuse is fine. No burnt resistors.
Do you have a suggestion for websites where I could find the scheme for this radio to help me navigate through the board without desoldering and checking every component one by one? By the way, I'm not used to repair old radio equipment, so every suggestion is welcome! Slight smile
Thank you all
    0 dougw 7 months ago
    Check the power supply voltages to see if all circuits are getting proper voltage.
    Check that all switches and knobs perform properly.
    Check the antenna is in good shape and connected.
    See if you can find the oscillator and check if it is working.
    Does it produce any sound at all? Static hiss? Does the volume knob increase the hiss?
  • robogary
    0 robogary 7 months ago
    Caps may look OK,  but electrolytics deserve special scrutiny.
  • strb
    0 strb 7 months ago in reply to dougw
    Supply voltages are fine.
    Switches and knobs works ok. I found one pot that is a bit "jittery" but it works.
    I've exluded antenna and oscillator stage up to now, as this radio has an aux input on the back. I'm using that input to inject signals with a waveform generator (AC coupled). L/R signals arrive to the amplier board but only one channel is working. Volume knob changes signal amplitude on the working channel, the other output is dead. At the moment I'm using a scope to probe output signals, I've not connected any speaker yet.
    I managed to probe the base of the output transistor (high side) for both channels. The working one is at Vcc/2, while the other one is stuck at Vcc. I'm trying to work backward from that.
    Than you for your kind suggestions!
  • strb
    0 strb 7 months ago in reply to robogary
    Ok, I'll have a closer look. What should I look for? I can easily measure capacitance with my multimeter, but I don't have a LCR to check ESR.
    Thank you!
    0 shabaz 7 months ago
    I checked radiomuseum (which very often has circuit diagrams) but they have zero from that manufacturer. No photos of the interior are on their site either : (
    0 dougw 7 months ago in reply to strb
    When you removed the output transistor was the base signal still stuck at VCC?
  • strb
    0 strb 6 months ago in reply to dougw
    I did not measure that without the output transistor. I'll have a look. I expect to find it stuck at Vcc as well, but we will see.
  • strb
    0 strb 6 months ago in reply to shabaz
    Thank you for having a look!
