Spring Clean!
  • Spring Clean!
Spring Clean!
Forum Garden Light
  • News and Projects
Join Spring Clean! to participate - click to join for free!
  • Replies 20 replies
  • Subscribers 102 subscribers
  • Views 930 views
Garden Light
scottiebabe
scottiebabe 5 months ago
One of the solar garden lights was in desperate need of some spring cleaning.
The top rubber button cover had rotted over time and began to leak when it rains.
Almost all of the internals were in dire straits.
Before taking everything apart, I tried tinning the batery contacts with fresh solder to see if that was the only issue, it was not.
Even the solar charge/led driver IC (qx5252) had two of its leads corrode away.
I made a brief attempt to solder to what was left of the lead frame with limited success. Eventually with some cleaning and scraping I was able to make a connection.
I also tossed something together with an ME2108 module.
When the solar panel stops sourcing charge current Q1 turns on lightly. As the output of the me2108 module rises M1 starts to conduct and provide a “low” resistance to ground. Q2 pulls the gate of m1 low, thus disabling the boost module, should the solar panel starts sourcing current before the battery dies.
Surprisingly the solar panel was still functional. I have had a few lights where panel connections corrode away. Many of these cheap lights don't put much effort into waterproofing the solar connections.
  • beacon_dave
    beacon_dave 5 months ago +6
    Bonus points for your 'Spring Cleaning' literally involving cleaning a spring Is anyone doing anything creative with garden lighting projects ? If so I was wondering what materials and techniques…
  • scottiebabe
    scottiebabe 5 months ago in reply to JWx +5
    It doesn't matter to me where it is posted, but I was just sharing for fun
  • kmikemoo
    kmikemoo 5 months ago +4
    scottiebabe My wife LOVES these lights. We have dozens of them. She's even insisted on buying replacement batteries for them - although I could have bought new lights for what I paid for the batteries…
  • beacon_dave
    0 beacon_dave 5 months ago
    Bonus points for your 'Spring Cleaning' literally involving cleaning a spring Slight smile
    Is anyone doing anything creative with garden lighting projects ? If so I was wondering what materials and techniques were being used to make the designs weather and wildlife resistant as well as keeping the install maintainable and adaptable.
    • Vote Up +6 Vote Down
  • scottiebabe
    0 scottiebabe 5 months ago in reply to beacon_dave
    My bonus prize was letting the magic smoke out of the ic after patching the missing leads.
    There isn't a single capacitor on the pcb, it is identical to this
    I made a temporary battery connection with croc clips and an intermittent connection let the inductor kickback and toast the chip. Magic smoke prize.
  • scottiebabe
    0 scottiebabe 5 months ago in reply to colporteur
    I would agree that is generally true, I just happen to enjoy the lights when they are working and they are very easy to understand.
  • scottiebabe
    0 scottiebabe 5 months ago in reply to ralphjy
    That is an impressive amount of LEDS!
    I bought I solar spot light that runs on a lithium cell, it throws a decent amount of light but doesn't last all night.
    I put some clear silicon around the solar panel.
  • ralphjy
    0 ralphjy 5 months ago in reply to scottiebabe
    Good news is that it's motion activated, so it doesn't run continuously.  Bad news is that it turns on a lot.  Somewhat disconcerting that we have so many critters coming through at night.  Thankfully no coyotes yet, but lots of mice, bunnies, and occasionally possum and raccoon.  I'm sure it keeps the neighbors entertained as one of them has commented on it - I have 3 lights in back for coverage...
    0 genebren 5 months ago
    Great work!
    I have played around with updating/modifying some tired Solar LED fixtures in the past (https://community.element14.com/challenges-projects/project14/offtheshelf/b/blog/posts/off-the-shelf---outdoor-lighting-system-revamp).  Instead of solar, these fixtures were converted to wired, low voltage (5VDC) lights. These lights have been working for almost 5 years, with only one of the lights needing a bit of repair (water incursion created rust, which caused a poor connection, yielding a lower than normal light output on one of the hanging lights).  I have since added some path lights on to the circuit:
  • scottiebabe
    0 scottiebabe 5 months ago in reply to genebren
    That is gorgeous! Your lights appear to be custom stained glass.
    One of your excellent blogs show what the light puck above would have looked like new
    Except mine had a latching push button with rubber cover on the top (that eventually failed)
  • JoRatcliffe
    0 JoRatcliffe 5 months ago in reply to genebren
    Wow, they look great!
    0 genebren 5 months ago in reply to scottiebabe
    Yes, the lights are based on Corning glass blocks (shower blocks?) that have been mosaiced with custom images by my wife (seen above walking up to the deck stairs).  The lights elements are custom made and detailed here (https://community.element14.com/members-area/personalblogs/b/gene-breniman-s-blog/posts/outdoor-lighting---light-up-my-path) .  This is a long running project (like a lot of mine) that has finally completed.  I plan to do a blog to document more of the project.
    0 DAB 5 months ago
    Great save.
