Techno Toys
  • Techno Toys
Techno Toys
Blog Sparky the Power Chick Levitates - Happy New Year
Join Techno Toys to participate - click to join for free!
  • Author Author: dougw
  • Date Created: 2 Jan 2019 2:13 AM Date Created
  • Views 3861 views
  • Likes 15 likes
  • Comments 14 comments
  • sparky the power chick
  • doug wong
  • merryboxesledsch
  • holidayspecial19ch
  • electromagnetismch
  • magnetic levitation
  • ttoysch
  • sparky
  • merryboxesledch
  • merry boxes & leds
dougw
dougw
2 Jan 2019
Merry Boxes & LEDs
Enter Your Project for a chance to win a Maker Tool Kit, an Oscilloscope Grand Prize for the project that brings the Most Joy to the Heart, and Gift to Gives!
Project14 Home
Monthly Themes
Monthly Theme Poll
Sparky returns .....
Just a little fun and levity to say Happy New Year!
Nothing like a cute new-born chick to welcome a new year...
I have been fooling around with magnetic levitation - will try to work it into a project this year.
Here is a link to a previous sparky appearance.
    dougw over 7 years ago in reply to 14rhb +5
    You are correct - there are lots of magnets and electromagnets under the cloth. Some are repelling and some are attracting. Definitely a feedback/control system - the electromagnets are controlled by 3…
    genebren over 7 years ago +4
    Very cute. And a Happy New Year to you! Gene
    balearicdynamics over 7 years ago +4
    Cute Doug! When we should expect this chick grows? I want to see how you solve the problem to make eggs Enrico
  • mahmood.hassan
    mahmood.hassan over 7 years ago
    Hello Sir;
    I am trying to build a 3D levitation system in which you can suspend anything irrespective of outter body position. But the main problem I have been facing is the huge currents consumption.
    Do you have idea how to control current consumption (with series resistance) and coils heating problem.
    dougw over 7 years ago in reply to mahmood.hassan
    Heat is definitely an issue with many of these systems. To decrease the coil current you can increase the number of turns in the coil, but the increased inductance makes it harder to achieve high speed field changes which are needed for stability. You can increase the wire diameter (gauge) to decrease its resistance, but the coils get significantly larger and may not fit the design geometry. You could run a fan, but then you need to worry about the magnetic fields from the motor complicating the magnetic field control system. Additionally the airflow may disturb the levitating object.
    I am trying to design a system with heatsinks, but it isn't just about understanding thermodynamics, it will likely need some iteration as it may suffer from eddy current heating and eddy current magnetic fields, and even disturbed airflow.
    Currently, I just turn the system off and let it cool down when it gets too hot.
  • mahmood.hassan
    mahmood.hassan over 7 years ago in reply to dougw
    I have tried this by increasing the wire diameter --> low resistance --> lots of current --> lots of heat --> image
    If I decrease the supply --> less current --> weaker magnetic effect --> image
    I am also following the supply off and wait routine.
    I am worried about enameled layer on the wire because over heating can damage it.
  • three-phase
    three-phase over 7 years ago in reply to mahmood.hassan
    If you have the specification from the manufacturer of the wire, that will tell you what temperature the insulation can withstand, thermal classes generally range from 130 Degrees C up to 250 Degrees C.
    You can also usually find out what the maximum current rating of the wire is, and as long as you are below that then the insulation should not become damaged.
    If that information is not available then if you can measure the diameter of the wire accurately, you could utilise a general table, linked below, to gain a typical current rating.
    Wire Gauge: Nikola Tesla Page
    Knowing the rating, you may be able to build a current limiting circuit to control it.
    Kind regards.
