Test Instrumentation
  • Test Instrumentation
Blog MinMax - Calibration Box
Join Test Instrumentation to participate - click to join for free!
  • Author Author: rsc
  • Date Created: 2 Oct 2018 6:32 PM Date Created
  • Views 1417 views
  • Likes 14 likes
  • intermediate micro:bit projects
  • microbit projects
  • microbit
  • intermediate_microbit_projects
  • stem projects
  • diytestinstruch
rsc
rsc
2 Oct 2018
Enter Your Electronics & Design Project for a chance to win a Grand Prize for Originality, a Tool Set, and a $100 Shopping Cart!
Project14 Home
Monthly Themes
Monthly Theme Poll
When working with data acquisition systems, many times a signal doesn't behave as expected.  When diagnosing the problem, it's nice to have a reference voltage to test your inputs.
I made up this quick "MinMax" test box for quickly testing analog inputs.  The MinMax is built from four simple parts, a set of banana jacks for input voltage, a BNC output jack, a variable resistor, and a box.
I have one with a 1K 1 turn pot, and one using a 10 turn 100K pot for testing opamp circuits. VCC can be 3.3V, 5V, 12V, or whatever your circuit needs.  I made one up with a 1A analog meter inline also.
*** Note *** there is not a current limiting resistor inline, or a fuse, so if you short the BNC, you can short your power supply.
To use the box:
1) Apply power and ground to the red(+) and black(-) banana jacks
2) Connect BNC to DAQ input, and connect in parallel to voltmeter if needed.
3) Adjust output from 0-100%
Here's a schematic:
Here's the unit:
Simple, but useful.
Add a micro:bit, some switches, and display, and you have a programmable analog test instrument.
Since you sent me a micro:bit, here's a simple voltage output device program.
If button "B" is pressed, the voltage output is increased, if "A" is pressed, the voltage is decreased.
The voltage is approximated by the LEDs as a bargraph.
    genebren over 8 years ago +5
    Simple is sometimes better complex. If it gets the job done, then all is good. Gene
    shabaz over 8 years ago +3
    That's a cool name for a project : ) I've never thought of doing this, until very recently when I was trying to control 4 analog quantities. Until my project changed, I was about to build a general-purpose…
  • three-phase
    three-phase over 7 years ago +1
    Very useful project to build up. Kind regards.
    Gene
    • Vote Up +5 Vote Down
    Gene
