Vision Thing
  • Vision Thing
Vision Thing
Forum BB AI and OpenCV 3.3+
Join Vision Thing to participate - click to join for free!
  • Subscribers 9 subscribers
  • Views 1533 views
  • bb-ai
  • opencv
  • ai
  • dnn
  • deep neural network
  • deep neural networks
vlasov01
vlasov01 over 7 years ago
I know BB AI comes with OpenCV 3.2.
I'd like to use BB AI with OpenCV Deep Neural Networks (dnn module) on my project. It comes with OpenCV 3.3 or later.
I'm wondering if anyone was able to get OpenCV 3.3 or later for BB AI?
If yes, are you still benefiting from BB AI hardware accelerators?
  • ajcc
    ajcc over 7 years ago in reply to clem57 +1
    Arguments given to su will be interpreted as usernames, you're thinking of sudo sudo python -c "import cv2; print(cv2.__version__)"
  • clem57
    clem57 over 7 years ago in reply to ajcc +1
    I was really thing su and next line your command under root of course. But sudo also...
  • vlasov01
    I was able to build OpenCV 4.1.2 on BB AI.
    (cv) debian@beaglebone:~$ python -c "import cv2; print(cv2.__version__)"
    4.1.2
    I'm not sure yet if it is using accelerators as I'm getting "TIOCL FATAL: Failed to open file /dev/mem" error when I'm calling dnn module from python.
  • clem57
    clem57 over 7 years ago in reply to vlasov01
    Use su before python command.
  • ajcc
  • clem57
    I was really thing
    su
    But sudo also...
  • vlasov01
    vlasov01 over 7 years ago in reply to ajcc
    Hi Adrian,
    I'm using virtual python environment. And it was setup only for user debian. So when I run the command you suggested it is running it using a different version of OpenCV:
    3.2.0
    And I was looking for OpenCV 3.3+ as it has support for dnn.
    I've tried another approach:
    cd /home/debian/.virtualenvs/cv/bin/
    sudo setcap cap_sys_rawio+ep python3
    But it gave me another error:
    * FATAL ERROR:                                                   *
    * This OpenCV build doesn't support current CPU/HW configuration *
    * Use OPENCV_DUMP_CONFIG=1 environment variable for details      *
    Required baseline features:
        ID=100 (NEON) - NOT AVAILABLE
    terminate called after throwing an instance of 'cv::Exception'
      what():  OpenCV(4.1.2) /home/debian/opencv/modules/core/src/system.cpp:598: error: (-215:Assertion failed) Missing support for required CPU baseline features. Check OpenCV build configuration and required CPU/HW setup. in function 'initialize'
    Aborted
    And if I set OPENCV_DUMP_CONFIG=1 then I'm getting the followimng information about my OpenCV configuration:
    OpenCV build configuration is:
    General configuration for OpenCV 4.1.2 =====================================
      Version control:               unknown
      Extra modules:
        Location (extra):            /home/debian/opencv_contrib/modules
        Version control (extra):     unknown
      Platform:
        Timestamp:                   2019-10-27T02:57:31Z
        Host:                        Linux 4.14.108-ti-r122 armv7l
        CMake:                       3.7.2
        CMake generator:             Unix Makefiles
        CMake build tool:            /usr/bin/make
        Configuration:               RELEASE
      CPU/HW features:
        Baseline:                    NEON
          requested:                 DETECT
          required:                  NEON
          disabled:                  VFPV3
      C/C++:
        Built as dynamic libs?:      YES
        C++ Compiler:                /usr/bin/c++  (ver 6.3.0)
        C++ flags (Release):         -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-psabi -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections  -mfpu=neon -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG  -DNDEBUG
        C++ flags (Debug):           -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-psabi -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections  -mfpu=neon -fvisibility=hidden -fvisibility-inlines-hidden -g  -O0 -DDEBUG -D_DEBUG
        C Compiler:                  /usr/bin/cc
        C flags (Release):           -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-psabi -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections  -mfpu=neon -fvisibility=hidden -O3 -DNDEBUG  -DNDEBUG
        C flags (Debug):             -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-psabi -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections  -mfpu=neon -fvisibility=hidden -g  -O0 -DDEBUG -D_DEBUG
        Linker flags (Release):      -Wl,--gc-sections
        Linker flags (Debug):        -Wl,--gc-sections
        ccache:                      NO
        Precompiled headers:         NO
        Extra dependencies:          dl m pthread rt
        3rdparty dependencies:
      OpenCV modules:
        To be built:                 aruco bgsegm bioinspired calib3d ccalib core datasets dnn dnn_objdetect dnn_superres dpm face features2d flann freetype fuzzy gapi hfs highgui img_hash imgcodecs imgproc line_descriptor ml objdetect optflow phase_unwrapping photo plot python3 quality reg rgbd saliency shape stereo stitching structured_light superres surface_matching text tracking ts video videoio videostab xfeatures2d ximgproc xobjdetect xphoto
        Disabled:                    world
        Disabled by dependency:      -
        Unavailable:                 cnn_3dobj cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev cvv hdf java js matlab ovis python2 sfm viz
        Applications:                perf_tests apps
        Documentation:               NO
        Non-free algorithms:         YES
      GUI:
        GTK+:                        YES (ver 3.22.11)
          GThread :                  YES (ver 2.50.3)
          GtkGlExt:                  NO
        VTK support:                 NO
      Media I/O:
        ZLib:                        /usr/lib/arm-linux-gnueabihf/libz.so (ver 1.2.8)
        JPEG:                        /usr/lib/arm-linux-gnueabihf/libjpeg.so (ver 62)
        WEBP:                        build (ver encoder: 0x020e)
        PNG:                         /usr/lib/arm-linux-gnueabihf/libpng.so (ver 1.6.28)
        TIFF:                        /usr/lib/arm-linux-gnueabihf/libtiff.so (ver 42 / 4.0.8)
        JPEG 2000:                   build (ver 1.900.1)
        OpenEXR:                     /usr/lib/arm-linux-gnueabihf/libImath.so /usr/lib/arm-linux-gnueabihf/libIlmImf.so /usr/lib/arm-linux-gnueabihf/libIex.so /usr/lib/arm-linux-gnueabihf/libHalf.so /usr/lib/arm-linux-gnueabihf/libIlmThread.so (ver 2.2.0)
        HDR:                         YES
        SUNRASTER:                   YES
        PXM:                         YES
        PFM:                         YES
      Video I/O:
        DC1394:                      YES (2.2.5)
        FFMPEG:                      YES
          avcodec:                   YES (57.64.101)
          avformat:                  YES (57.56.101)
          avutil:                    YES (55.34.101)
          swscale:                   YES (4.2.100)
          avresample:                YES (3.1.0)
        GStreamer:                   NO
        v4l/v4l2:                    YES (linux/videodev2.h)
      Parallel framework:            pthreads
      Trace:                         YES (with Intel ITT)
      Other third-party libraries:
        Lapack:                      NO
        Eigen:                       NO
        Custom HAL:                  YES (carotene (ver 0.0.1))
        Protobuf:                    build (3.5.1)
      OpenCL:                        YES (no extra features)
        Include path:                /home/debian/opencv/3rdparty/include/opencl/1.2
        Link libraries:              Dynamic load
      Python 3:
        Interpreter:                 /home/debian/.virtualenvs/cv/bin/python3 (ver 3.5.3)
        Libraries:                   /usr/lib/arm-linux-gnueabihf/libpython3.5m.so (ver 3.5.3)
        numpy:                       /home/debian/.virtualenvs/cv/lib/python3.5/site-packages/numpy/core/include (ver 1.17.3)
        install path:                /home/debian/.virtualenvs/cv/lib/python3.5/site-packages/cv2/python-3.5
      Python (for build):            /usr/bin/python2.7
      Java:
        ant:                         NO
        JNI:                         NO
        Java wrappers:               NO
        Java tests:                  NO
      Install to:                    /usr/local
