Vision Thing
  • Vision Thing
Vision Thing
Forum Not enough disk space for apt upgrade on Beaglebone AI
Join Vision Thing to participate - click to join for free!
  • Replies 17 replies
  • Answers 5 answers
  • Subscribers 11 subscribers
  • Views 8479 views
weiwei2
weiwei2 over 7 years ago
I face a not enough space left on device after attempting to do sudo apt upgrade on the device.
the same scenario happen if i try to update the cloud9 by pulling by following example in https://beagleboard.org/upgrade
i also try to follow https://www.hackster.io/175809/tidl-on-beaglebone-ai-1ee263  but all of these will fail at the same 'not enough space scenario'
originally i thought the 8GB sd card i use is really insufficient then i change to a much bigger one and realize problem persists....then it must be something wrong
below is my sudo apt update and the subsequent sudo apt upgrade procedure
debian@beaglebone:/var/lib/cloud9$ sudo apt update
[sudo] password for debian:
Ign:1 http://deb.debian.org/debian stretch InRelease
Get:2 http://deb.debian.org/debian stretch-updates InRelease [91.0 kB]
Get:3 http://repos.rcn-ee.com/debian stretch InRelease [3,064 B]
Get:4 http://deb.debian.org/debian-security stretch/updates InRelease [94.3 kB]
Get:5 http://deb.debian.org/debian stretch Release [118 kB]
Get:6 http://deb.debian.org/debian stretch Release.gpg [2,365 B]
Get:7 http://deb.debian.org/debian stretch-updates/main armhf Packages [27.3 kB]
Get:8 http://repos.rcn-ee.com/debian stretch/main armhf Packages [1,066 kB]
Get:9 http://deb.debian.org/debian-security stretch/updates/main armhf Packages [484 kB]
Get:10 http://deb.debian.org/debian-security stretch/updates/contrib armhf Packages [1,764 B]
Get:11 http://deb.debian.org/debian-security stretch/updates/non-free armhf Packages [1,272 B]
Get:12 http://deb.debian.org/debian stretch/main armhf Packages [6,915 kB]
Get:13 http://deb.debian.org/debian stretch/contrib armhf Packages [42.1 kB]
Get:14 http://deb.debian.org/debian stretch/non-free armhf Packages [59.7 kB]
Fetched 8,906 kB in 17s (511 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
56 packages can be upgraded. Run 'apt list --upgradable' to see them.
debian@beaglebone:/var/lib/cloud9$ sudo apt upgrade
Calculating upgrade... Done
The following packages have been kept back:
  chromium
The following packages will be upgraded:
  base-files bb-cape-overlays bonescript e2fslibs e2fsprogs gpiod libcomerr2 libcpupower1 libcups2 libexpat1 libexpat1-dev libgd3 libglib2.0-0 libgpiod2 libicu57 libiio-utils libiio0
  libldap-2.4-2 libldap-common libmariadbclient18 libnghttp2-14 libnginx-mod-http-auth-pam libnginx-mod-http-dav-ext libnginx-mod-http-echo libnginx-mod-http-geoip
  libnginx-mod-http-image-filter libnginx-mod-http-subs-filter libnginx-mod-http-upstream-fair libnginx-mod-http-xslt-filter libnginx-mod-mail libnginx-mod-stream libpam-systemd libpq5
  libss2 libssl1.0.2 libssl1.1 libsystemd0 libudev-dev libudev1 libxslt1.1 linux-cpupower linux-libc-dev nginx nginx-common nginx-full openssh-client openssh-server openssh-sftp-server
  openssl systemd systemd-sysv tzdata udev unzip usbutils
55 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 32.0 MB of archives.
After this operation, 194 kB of additional disk space will be used.
E: You don't have enough free space in /var/cache/apt/archives/.
subsequently i do a fdisk -l for my very huge sd card after reading about https://www.linuxquestions.org/questions/debian-26/no-space-left-on-device-880308/  but unsure if i can follow it
here's my fdisk output
debian@beaglebone:/var/lib/cloud9$ sudo fdisk -l
Disk /dev/mmcblk0: 119.3 GiB, 128043712512 bytes, 250085376 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xf7146e7c
Device         Boot Start     End Sectors  Size Id Type
/dev/mmcblk0p1 *     8192 7372799 7364608  3.5G 83 Linux
Disk /dev/mmcblk1: 14.6 GiB, 15678308352 bytes, 30621696 sectors
Disklabel type: dos
Disk identifier: 0x209da4b7
/dev/mmcblk1p1 *     8192 30621695 30613504 14.6G 83 Linux
Disk /dev/mmcblk1boot1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk1boot0: 4 MiB, 4194304 bytes, 8192 sectors
  • mp2100
    mp2100 over 7 years ago in reply to weiwei2 +3 verified
    Wei, you had an 8 GB card, but the downloaded image is a 4 GB image. You found the manual instructions to expand the image to fill up your 8 GB card. On that page https://elinux.org/Beagleboard:Expanding_File_System_Partition_On_A_microSD…
  • weiwei2
    weiwei2 over 7 years ago +2 suggested
    i have found this page https://elinux.org/Beagleboard:Expanding_File_System_Partition_On_A_microSD and follow it. originally, my SD is /dev/mmcblk0p1 8192 7372799 7364608 3.5G 83 Linux after the successful…
  • clem57
    clem57 over 7 years ago +1
    Background: I read somewhere that the BB and probably the BB-AI creates a temporary space in RAM. If this contains your cache ( I bet it does ), that is the problem. To solve this, add a hard/soft link…
  • 14rhb
    0 14rhb over 7 years ago
    I'm kind of glad I'm still waiting for a power lead for my BB-AI as it appears many of the issues are being discussed and solutions found. So thanks to weiwei2 and clem57 for the useful information in this blog which I'll surely be using in a few days time.
  • mp2100
    0 mp2100 over 7 years ago in reply to weiwei2
    at the top, they give the automatic instructions.
    Existing on the beaglebone, there's a script that does all those steps for you,  "grow_partition.sh" you just have to run that script and it's done.
    <quote>
    On newer Debian system images coming from BeagleBoard.org / Robert Nelson, you can run the script:
    sudo /opt/scripts/tools/grow_partition.sh
    <endquote>
  • clem57
    0 clem57 over 7 years ago
    I solved this one by the following:
    1. Downloaded the latest image for Beagle Bone AI from BeagleBone.org
    2. Used Etcher to burn the image to a fairly large SD card. I used a good named brand...
    3. Booted the Beagle Bone AI with card inserted.
    4. Checked space with df -h
    5. Run shell /opt/scripts/tools/grow_partition.sh
    6. Reboot BB-AI.
    7. Check space again with df -h  You should see / expanded to the rest of the card.
    8. Run sudo apt update
    9. Run sudo apt upgrade
    10. Now if you want, flash eMMC. I chose not to do this step. I would be careful since you could run into troubles if the card now exceeds 16 Gimage
    11. Enjoy the new and improved Linux!image
  • mudz
    0 mudz over 7 years ago in reply to clem57
    There must be a way to run OS on eMMC flash While other files on sd card.
  • clem57
    0 clem57 over 7 years ago in reply to mudz
    There is if you are willing to partition out the / (root) into pieces. I have done this on X86 with SSD...
    Clem
  • weiwei2
    0 weiwei2 over 7 years ago in reply to mp2100
    wow thanks...although i read the same manual, i miss the first line that mention that automated script, and proceeded to do all the manual steps in that page.
  • weiwei2
    0 weiwei2 over 7 years ago in reply to clem57
    thanks. Hopefully this gets reflected in the beagbleboard getting started page https://beagleboard.org/getting-started
