Vision Thing
  • Vision Thing
Vision Thing
Forum Installing OpenCV is Like...
Join Vision Thing to participate - click to join for free!
  • Replies 21 replies
  • Answers 17 answers
  • Subscribers 13 subscribers
  • Views 5683 views
  • visionthingch
  • bb-ai
  • ibox
  • opencv
  • ai
14rhb
14rhb over 7 years ago
After several days into attempting to install OpenCV on my BB-AI it feels like I'm at about 0:15s into this video !
https://www.youtube.com/watch?v=wmFzGXy5uYc
Maybe some pointers for others are in my iBox posts:
iBox: #2 Setting up the BB-AI
iBox: #3 Is it a cat, a plane, a moth?
I also tried cross compiling on my faster PC with the aim of porting the code across afterwards, but that too failed with the libpython2-dev:armhf library not being found. After much adjustment of my machine on the Linux command line I'm also no nearer on that approach.
But it did make me think, hence this question rather than a blog post:
If I were to compile the OpenCV on my other machine and port it across to the BB-AI then has someone else done this? e.g. why am I sitting waiting days for the BB-AI to run CMAKE if it could be done externally and highly likely someone already has.
I've learnt many Linux commands along the way and have a rough understanding of what cross-compiling is.....so progress todate has been worthwhile still image
    shabaz over 7 years ago +9 verified
    Hi Rod! I can't recall how long it took to compile OpenCV from scratch on a BeagleBone Black, but it's doable (within hours but cannot remember how many!), so BB-AI should work nicely too. If I can make…
  • 14rhb
    14rhb over 7 years ago in reply to shabaz +5 suggested
    Hi Shabaz, Thank you for that good advice and insight into what cross-compiling is about. I'm back on the BB-AI directly, albeit via SSH, and having another go at following the instructions on the OpenCV…
    shabaz over 7 years ago in reply to 14rhb +5 suggested
    Hi Rod, The 1GByte RAM should be fine (as you say, not running the desktop should speed things up) since the older BBB can compile OpenCV too. Regarding storage, if you've got any existing home NAS (e…
  • yosoufe
    0 yosoufe over 6 years ago
    What about cross-compile with docker container? i haven't done it but it may work
    I found a page for cross-compiling for raspberry pi in docker container here: https://desertbot.io/blog/how-to-cross-compile-for-raspberry-pi
