Vision Thing
  • Vision Thing
Vision Thing
Forum Installing OpenCV is Like...
Join Vision Thing to participate - click to join for free!
  • Replies 21 replies
  • Answers 17 answers
  • Subscribers 13 subscribers
  • Views 5675 views
  • visionthingch
  • bb-ai
  • ibox
  • opencv
  • ai
14rhb
14rhb over 7 years ago
After several days into attempting to install OpenCV on my BB-AI it feels like I'm at about 0:15s into this video !
https://www.youtube.com/watch?v=wmFzGXy5uYc
Maybe some pointers for others are in my iBox posts:
iBox: #2 Setting up the BB-AI
iBox: #3 Is it a cat, a plane, a moth?
I also tried cross compiling on my faster PC with the aim of porting the code across afterwards, but that too failed with the libpython2-dev:armhf library not being found. After much adjustment of my machine on the Linux command line I'm also no nearer on that approach.
But it did make me think, hence this question rather than a blog post:
If I were to compile the OpenCV on my other machine and port it across to the BB-AI then has someone else done this? e.g. why am I sitting waiting days for the BB-AI to run CMAKE if it could be done externally and highly likely someone already has.
I've learnt many Linux commands along the way and have a rough understanding of what cross-compiling is.....so progress todate has been worthwhile still image
    shabaz over 7 years ago +9 verified
    Hi Rod! I can't recall how long it took to compile OpenCV from scratch on a BeagleBone Black, but it's doable (within hours but cannot remember how many!), so BB-AI should work nicely too. If I can make…
  • 14rhb
    14rhb over 7 years ago in reply to shabaz +5 suggested
    Hi Shabaz, Thank you for that good advice and insight into what cross-compiling is about. I'm back on the BB-AI directly, albeit via SSH, and having another go at following the instructions on the OpenCV…
    shabaz over 7 years ago in reply to 14rhb +5 suggested
    Hi Rod, The 1GByte RAM should be fine (as you say, not running the desktop should speed things up) since the older BBB can compile OpenCV too. Regarding storage, if you've got any existing home NAS (e…
  • 14rhb
    0 14rhb over 6 years ago in reply to clem57
    Thank you fyaocn that was a real insight and is going to help me along really well - seems like I have v3.2.2 installed by default....now to try it out.
  • fyaocn
    0 fyaocn over 6 years ago in reply to clem57
    Here it is.
    You can #include directories from /usr/include , etc.
  • fyaocn
    0 fyaocn over 6 years ago in reply to 14rhb
    That is really fun digging into the Framework and Software Structures.
    But only one month left for the Vision Things, I am really eager to see how your project going on. Have to admit that, it is not easy.
    0 shabaz over 6 years ago in reply to fyaocn
    I didn't realize it was up to v4.x already!
    I've only used opencv2, it has the advantage perhaps that there's lots of literature on it.. at least, the books I found at the time I tried it all referred to opencv2.
  • skywalker1211
    0 skywalker1211 over 6 years ago in reply to 14rhb
    there is no error message. i got the same problem when i compile opencv4 in raspi2. increase swap space solve the problem.
    https://linuxize.com/post/how-to-install-opencv-on-raspberry-pi/    --->   "Start by increasing the swap space to avoid compilation hangups due to memory problems:"
  • 14rhb
    0 14rhb over 6 years ago in reply to skywalker1211
    Thank you for this useful information skywalker1211 - do you have any recommendations for what you changed the swap space to?
  • skywalker1211
    14rhb
    i changed from 100 -> 1024, and revert after installation.
  • vlasov01
    0 vlasov01 over 6 years ago in reply to skywalker1211
    I'm wondering if you noticed any performance differences between supplied OpenCV 3.2 and v4 for image processing tasks? Is v4 still leveraging DSP and EVE cores of AM5729?
  • skywalker1211
    0 skywalker1211 over 6 years ago in reply to vlasov01
    i don't have a BB AI. i install opencv4 into raspi2.
  • vlasov01
    Thank you for the reply!
    I'm building now OpenCV 4.1.2 on BB AI. So I'll get my answers soon.
