Project14
Project14
Documents Project14 | You Decide the Next Monthly Project Competition!
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Date Created: 10 May 2017 8:26 PM Date Created
  • Last Updated Last Updated: 23 Sep 2024 3:52 PM
  • Views 61620 views
  • Likes 20 likes
  • Comments 338 comments
In the Forums or as an Idea:  Send Your Suggestions for Future Themes and vote on them!
 Forum  / Theme Suggestions
How are Themes selected?
 Project14 | Quick Update on Upcoming Competitions + What Would You Like To See Happen In Project14?
  • led display
  • communication_protocol
  • music tech
  • home automation
  • decide the next monthly project competition!
  • monthly_project
  • project14 featured
  • arduino home automation
  • analog devices
  • analog & digital wireless communication
  • project14
  • test & measurement
  • arduino communication
  • analog on pi
    dougw over 9 years ago +24
    I guess the suggestion box moved here so I will reiterate one idea I mentioned earlier and add one: - a classroom demonstration of some physics phenomenon ( jc2048 had some good ideas ) - a solar powered…
  • jack.chaney56
    jack.chaney56 over 9 years ago +11
    Keeping with July and (northern hemisphere) Summer time, I like Douglas' ideas. Demonstration of physical phenomenon for classroom is a great avenue, I was thinking lots of solar stuff. Charging systems…
    balearicdynamics over 9 years ago in reply to Workshopshed +11
    I will ad also a time machine. Sound good ? Enrico
  • kk99
    kk99 over 8 years ago
    Here are two my ideas for upcoming contests:
    - device based on analog electronics,
    - low power device e.g. we could create electronic eco-marathon where win device which works on the same battery the longest time
  • koudelad
    koudelad over 8 years ago in reply to kk99
    I also previously suggested a low power device theme and the contest idea is great. However, it depends on what kind of low power image It might end up with a contest running for years, maybe even decades image
  • koudelad
  • kk99
    kk99 over 8 years ago in reply to koudelad
    Yes i agree with you. But for this contest we should focus on reasonable duration. So, everything depends on contest conditions e.g.:
    - device which is participating in contest must use battery with size 500mAh,
    - we need think about task for which way of resolving should have influence in power usage and can be solved in many different ways,
    - device should report solution to server.
    Wins this device which have a biggest number of properly solved tasks and works on battery a longest time.
    What do you think about it ?
    mcb1 over 8 years ago in reply to kk99
    Project14 was designed to be for experienced and un-experienced, and featured a simple theme.
    The judging is decided on based on the content and it's appeal to a large degree.
    Once you starting getting into this sort of detail, it's getting closer to a Design Challenge image
    Low Power
    As you said, unless there are specifics, then it could run for years.
    Already I can see gains by choosing a few 500 mAH batteries and testing for the one that exceeds the specs .....
    I was thinking that something that ran from 2x AAA batteries, but what sort of task becomes the problem.
    You can make an Arduino run for months, however if it's waking up and doing the task once every hour, it is hardly real time monitoring.
    There has been a few low power 'competitions' run in the past, with some surprising results.
    Cheers
    ark
  • kk99
    kk99 over 8 years ago in reply to mcb1
    Ok, I agree with you. Even when we create some rules for this low power contest it will not fit to general idea of monthly theme. As you mention it will be design challenge. What about theme with analog device ? It gives user a lot of degrees of freedom e.g. you could create simple fm receiver or audio amplifier ?
    Jan Cumps over 8 years ago in reply to mcb1
    you could make it Low Power Themed without turning it into a Design Challenge.
    There is some playing ground in that subject that could fit Project 14...
  • tariq.ahmad
    tariq.ahmad over 8 years ago in reply to kk99
    Think something around analog and low power consumption are both good theme choices for the next poll.
    There was an analog fever theme in an earlier poll:
    Monthly Theme Poll for July 2017
    Could revisit this and do the other next time around.
    dougw over 8 years ago in reply to Jan Cumps
    I agree - it doesn't have to be a contest about the lowest possible power, it could simply be any project where low power was a feature, which is a huge scope.
    • Vote Up +5 Vote Down
    mcb1 over 8 years ago in reply to dougw
    What about low power and battery.? image
    I agree that there is room for Low Power and the options are huge
  • jomoenginer
    jomoenginer over 8 years ago in reply to tariq.ahmad
    Low power analog design is an interesting area.  Energy Harvesting though something like an EnOcean Kinetic Energy Harvesting Switch or a Haptic Feedback device would be items to look at.  Think back to the early Swiss Battery operated watches which were some of the original low powered analog devices.
    Jan Cumps over 8 years ago in reply to jomoenginer
    Yes, or maybe a simple "Do something inspired by low energy" ?
    That would be a low barrier so that anyone can enter.
