Internet of the Backyard
  • Internet of the Backyard
Blog [iot_umbrella] #05 start coding ...
  • Author Author: .lukasz.
  • Date Created: 5 Sep 2014 6:16 PM Date Created
  • Views 1005 views
  • Comments 5 comments
  • iot_backyard
  • iot_umbrella
.lukasz.
.lukasz.
5 Sep 2014
Tomorrow I am going to start coding ...
In C++ I  have created my own operating system
( I wrote this os in last year, it based on polling )
But I have big problems with CC3200 and C++
So IoT project I must write in C,
in this case my operating system is unuseful,
more work for me
[update 01]
weather forecast working propertly
( 4* 3 hours prediction )
Received HTTP GET response data.
Return value: 3400
HTTP/1.1 200 OK
Server: nginx
Date: Sun, 14 Sep 2014 09:33:58 GMT
Content-Type: text/xml; charset=utf-8
Content-Length: 19082
Connection: keep-alive
X-Source: redis
Access-Control-Allow-Origin: *
Access-Control-Allow-Credentials: true
Access-Control-Allow-Methods: GET, POST
<?xml version="1.0" encoding="utf-8"?><weatherdata>  <location>    <name>Starosielce</name>    <type/>    <country>PL</country>    <timezone/>    <location altitude="0" latitude="53.13353" longitude="23.075291" geobase="geonames" geobaseid="0"/>  </location>  <credit/>  <meta>    <lastupdate/>    <calctime>0.096</calctime>    <nextupdate/>  </meta>  <sun rise="2014-09-14T04:00:32" set="2014-09-14T16:45:42"/>  <forecast>    <time from="2014-09-14T06:00:00" to="2014-09-14T09:00:00">      <symbol number="800" name="sky is clear" var="01d"/>      <precipitation/>      <windDirection deg="68.0027" code="ENE" name="East-northeast"/>      <windSpeed mps="3.56" name="Gentle Breeze"/>      <temperature unit="celsius" value="27.78" min="15.36" max="27.78"/>      <pressure unit="hPa" value="1015.58"/>      <humidity value="81" unit="%"/>      <clouds value="clear sky" all="0" unit="%"/>    </time>    <time from="2014-09-14T09:00:00" to="2014-09-14T12:00:00">      <symbol number="800" name="sky is clear" var="01d"/>      <precipitation/>      <windDirection deg="77.0003" code="ENE" name="East-northeast"/>      <windSpeed mps="4.06" name="Gentle Breeze"/>      <temperature unit="celsius" value="33.1" min="21.3" max="33.1"/>      <pressure unit="hPa" value="1015.74"/>      <humidity value="76" unit="%"/>      <clouds value="clear sky" all="0" unit="%"/>    </time>    <time from="2014-09-14T12:00:00" to="2014-09-14T15:00:00">      <symbol number="800" name="sky is clear" var="01d"/>      <precipitation/>      <windDirection deg="89.0003" code="E" name="East"/>      <windSpeed mps="4.27" name="Gentle Breeze"/>      <temperature unit="celsius" value="34.78" min="23.6" max="34.78"/>      <pressure unit="hPa" value="1015.9"/>      <humidity value="67" unit="%"/>      <clouds value="clear sky" all="0" unit="%"/>    </time>    <time from="2014-09-14T15:00:00" to="2014-09-14T18:00:00">      <symbol number="800" name="sky is clear" var="01d"/>      <precipitation/>      <windDirection deg="92.5004" code="E" name="East"/>      <windSpeed mps="3.76" name="Gentle Breeze"/>      <temperature unit="celsius" value="33.39" min="22.84" max="33.39"/>      <pressure unit="hPa" value="1015.28"/>      <humidity value="61" unit="%"/>      <clouds value="clear sky" all="0" unit="%"/>    </time>    <time from="2014-09-14T18:00:00" to="2014-09-14T21:00:00">      <symbol number="800" name="sky is clear" var="01n"/>      <precipitation/>      <windDirection deg="77.0023" code="ENE" name="East-northeast"/>      <windSpeed mps="3.66" name="Gentle Breeze"/>      <temperature unit="celsius" value="27.6" min="17.67" max="27.6"/>      <pressure unit="hPa" value="1016.05"/>      <humidity value="65" unit="%"/>      <clouds value="clear sky" all="0" unit="%"/>    </time>    <time from="2014-09-14T21:00:00" to="2014-09-15T00:00:00">      <symbol number="800" name="sky is clear" var="01n"/>      <precipitation/>      <windDirection deg="79.0022" code="E" name="East"/>      <windSpeed mps="5.21" name="Gentle Breeze"/>      <temperature
Socket closed
SL Disconnect...
[WLAN EVENT]Device disconnected from the AP: LG-E610_8464, BSSID: c4:43:8f:d3:71:52 on application's request
GET_WEATHER: Test Complete
[update 02]
in this week I am going to add
1. lcd ( weather forecast display and interface with user )
2. gps (latitude and longitude for weather forecast and in future for umbrella positioning algorithm)
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago in reply to .lukasz.
    I look forward to seeing the results
    Peter
  • .lukasz.
    .lukasz. over 12 years ago in reply to Robert Peter Oakes
    in free time I read about freeRTOS,
    it isn't complicated, so make a decision that  I will use freeRTOS in umbrella project ,
    Good Choice, you can do the RTOS once the pressure of the challenge has passed and you have more time
  • .lukasz.
    thanks for advices
    I was thinking about freertos,
    but finally I decided for coding in C,
    why because 2 months it is not enough time for learning RTOS
    I am afraid that when I will be have problem with RTOS I will waste
    too many times for resolve them,,,
    additionally in this month I must also write second
    project for MSP430 FRAM, so I will be coding both project  in C
    b.r.
    Lukasz,
    There are several RTOS available from TI, many referenced directly in the Code Composer Studio help system
    RTOS (Real Time Operating System)
    this may be a great replacement for you old OS that will work on the device
