Essentials
  • Essentials
Essentials
Forum What 'Essentials' Electronics Topic would you like to Learn More About?
Join Essentials to participate - click to join for free!
  • Locked Locked
  • Replies 220 replies
  • Subscribers 1136 subscribers
  • Views 28195 views
  • suggest a new module
  • classes
  • essentials
  • essential modules
  • learning modules
  • suggest a topic
  • courses
jwatson
jwatson over 10 years ago
Enjoy DIY Learning Modules designed for engineers:
  • Short, self-paced learning anywhere, anytime
  • Technologies, Applications & Trivia
See Current Essentials Offerings
What Do You Want to Learn Next?  Share Your Suggestion by Replying below!
    dougw over 10 years ago +12
    sensors and signal conditioning
  • gadget.iom
    gadget.iom over 10 years ago +11
    A topic around micro-controllers might be useful.
  • jwatson
    jwatson over 10 years ago +10
    A 2 part IC Sensors Series is coming! Being published mid August and mid Sep!
  • neuromodulator
    neuromodulator over 8 years ago
    RF: antennas, distributed element circuits, filters, oscillators, etc
    power and signal integrity.
    photonics
  • atessmer
    atessmer over 8 years ago
    More about basics in AI... much  more!
  • nirbhay1
    nirbhay1 over 7 years ago
    Memories. RAM, ROM and various types of memories. Memory in an IC and their implementation with address line and data lines. Interfacing of memory chips.
  • phoenixcomm
    phoenixcomm over 7 years ago in reply to nirbhay1
    Oh PLEASE, NO DRAMS TOO MUCH PROBLEMS,
  • paulyvee
    paulyvee over 7 years ago
    Given the large range of mcu.s available a course on some definitive way of selecting the best for a particular job. This should not necessarily go to the level of selecting a particular device but at least select a manufacturer taking into account the programming level, and language ie microchip for example program very simply at assembler level with few commands to learn Others require a knowledge of higher languages but once past the (sometimes steep) learning curve of the new language may prove far easier to use, perhaps better or not.
    I have almost exclusively used microchip devices and assembler - yes Iam a bit old fasioned but in the end the devices have done what I wanted - perhaps not in the best way.and sometimes definately not the easiest It would be nice to have a wider selectionof devices sometimes but the learning path of any new assbler or new lanuage needs to be worthwhile
  • phoenixcomm
    phoenixcomm over 7 years ago in reply to paulyvee
    did that please read: Sizing an  embedded microprocessor
  • brycewilkins
    brycewilkins over 7 years ago
    How about a topic focused on Embedded Linux?  It could be an "Part II" extension to the existing Single Board Computers (SBC) learning module.
    The topic could introduce different Embedded Linux build systems (Yocto, builtroot, OpenWRT, etc.), highlight their differences, suitability for different types of projects, relationship with hardware (device tree), boot process (including uboot), and more!
    dougw over 7 years ago
    robotics
  • phoenixcomm
    phoenixcomm over 7 years ago in reply to brycewilkins
    BTW there is really nothing mysterious about the term "embedded"  its way overused, it is just a smaller kernel and the small bords are getting bigger, look at a laptop is that embedded? Yes. the line is very burly. Get out your dousing rods or the wigi board.
    I have a great working relationship with some of the projects as I have used them in one form or another. Basically, let us start with OpenWRT:  This just a group of very small images that can be used to flash routers, Like LinkSys. etc. It's all there. but not very useful for much else.
    Yocto: Now this beast is a neat way to build a custom distro. So if you want for example like my RSS, and some other boxes that in my simulator, NexGen, I can add, remove things from my deliverables, Like things I need a full system when I do development and testing, but, on my release distro, I can remove a lot of things my system does not use, and other things it must have. for instance, I don't need, games, browser(s), compilers and a lot of other trash. But on the other hand, I need things like the full TCP/.IP stack (and there are parts not included like some routing protocols), LUA, Phyton(?), Java, and Seat Control (UNIX speak for users).  My Distro is built on 3  images:
    1) The OS itself.
    2) The extra stuff.
    3) Deliverable Software.
    on other things I just use grub!
    Some of the servers use the boot system that has been around since before Windose! That is TFTP boot. If you wish to read more there is a very good write up here!
  • brycewilkins
    brycewilkins over 7 years ago in reply to phoenixcomm
    Hi Cris, good observation and I agree that what is/isn't "embedded" is rather blurred.  I would have called a system embedded if it were a specific/tailored hardware platform that includes microcontroller vs mircoprocessor, that is, high level of integration of GPIO, peripherals, SRAM, flash, etc. into the main processing chip.  This is a very constrained view...now even Raspberry Pi can be considered an embedded platform and yet it is entire computer!  Definitely very blurred!
    I like your suggestion to start with OpenWRT because its the most simplest framework...the easiest to understand.  Would be nice to include u-boot in the discussion (or cover it separately first) to understand the boot process from the very beginning.
