Essentials
  • Essentials
Essentials
Documents element14 Essentials: SBC - Related Single Board Computers
  • Author Author: randogless
  • Date Created: 29 May 2018 4:01 PM Date Created
  • Last Updated Last Updated: 25 Sep 2018 4:56 PM
  • Views 1672 views
element14 Learning Center
SBC: Single Board Computers
Sponsored byimage
The best way to get started with single board computers is to get a starter kit and build a project. To help you get started, we’ve listed some of the most common SBCs available from a variety of suppliers that you can use to experiment with coding, computing, or project-building.
Go to Single Board Computers Learning Module
Raspberry Pi
Raspberry Pi 3 Model B+
Starter Kit
Buy NowBuy Now
The Raspberry Pi is a great way to get started learning about single board computers.  The new Raspberry Pi 3 Model B+ Starter kit contains all the Raspberry Pi products you need to get started quickly. Featuring the new Raspberry Pi 3 Model B+, it is the latest product in the Raspberry Pi product line. It features a 64-Bit quad core processor running at 1.4GHz, dual band 2.4GHz / 5.0GHz wireless, Bluetooth 4.2/BLE, faster Ethernet, and PoE capability (via a separate PoE HAT). Features include:
image Broadcom BCM2837B0, Cortex-A53, 64-bit, quad-core SoC @ 1.4GHz
image 1GB LPDDR2 SDRAM
image 2.4GHz/5GHz IEEE 802.11 b/g/n/ac Wireless LAN (WLAN)
image Bluetooth Low Energy v4.2 (BLE)
image Gigabit Ethernet over USB 2.0 (maximum throughput 300Mbps)
image 4 x USB 2.0 Ports
image 40-pin GPIO Header
image Full Size HDMI, MIPI DSI display port, MIPI CSI camera port
image 4-pole stereo audio/composite video output port
BeagleBone
BeagleBone Black Wireless
Buy NowBuy Now
The BeagleBone Black Wireless is an open-source, maker-focused, single board computer. Focused on connectivity, the BeagleBone Black Wireless features a high-performance 802.11 b/g/n 2.4GHz WiFi module with Bluetooth. It also has an HDMI output, serial debug port, PC USB interface, USB 2.0 host, reset/power buttons, and has status LEDs for WiFi and Bluetooth. Features include:
image AM335x 1GHz ARMRegistered Cortex-A8
image SGX530 graphics accelerator
image NEON floating-point accelerator
image 2x PRU 32-bit 200MHzmicrocontrollers
image WiLink 1835 802.11b/g/n 2.4GHz WiFi, Bluetooth, and Bluetooth Smart Module
image USB client: power, debug and device
image USB host
image Micro HDMI output
image 512MB DDR3 800MHZ RAM
image 4GB Embedded eMMC Flash with Debian Distribution
image Software Compatibility: Debian, Android, Ubuntu
Beagle Black Industrial
Buy NowBuy Now
The BeagleBone Black Industrial is a BeagleBoard using a low cost industrial temperature grade SitaraTm AM3358 ARMRegistered CortexTm-A8 processor from Texas Instruments. It has a Debian Linux distribution preinstalled on the onboard FLASH, ready to start evaluation and development. Features include:
image Processor TI Sitara  AM3358BZCZA100AM3358BZCZA100 1GHz 2000 MIPS 1 GHz ARMRegisteredCortex-A8
image SGX530 Graphics Engine
image Programmable Real-Time Unit Subsystem
image Operating temperature can span from -40C to +85C
image Memory SDRAM: 512MB DDR3L 800MHZ
image Onboard Flash: 4GB, 8bit Embedded MMC
image SD/MMC Connector for microSD
image Power management:TPS65217C PMIC is used along with a separate LDO
image Debug Support: Optional Onboard 20-pin CTI JTAG, Serial Header
image Power Source miniUSB USB or DC Jack
image 5VDC External Via Expansion Header
image Connectivity High speed USB 2.0 Client port: Access to USB0, Client mode via miniUSB
image User Input / Output Reset Button
image Video/Audio Interfaces HDMI D type interface
image Expansion Interfaces LCD, UART, eMMC
Advantech
Advantech PCA-6743 Single Board Computer
Buy NowBuy Now
The PCA-6743 single board computer offers all the functions of an AT-compatible industrial computer on a single board. The CPU module supports DM&P Vortex86DX SOC (system on chip) which supports ISA interfaces. The Vortex86DX is a high performance and fully static 32-bit X86 processor compatible with Windows and DOS support. It also integrates 32KB write through 4-way L1 cache, 4-way 256KB L2 cache, PCI rev. 2.1 32-bit bus interface at 33 MHz, DDR2, ROM controller, IPC (Internal Peripheral Controllers with DMA and interrupt timer/counter included), Fast Ethernet, FIFO UART, USB2.0 Host and IDE controller within a single 581-pin BGA package to form a system-on-a-chip (SOC). The PCA-6743 is ideal for data-acquisition, environment monitoring, Intelligent Vehicle management, and factory automation. Features include:
image Ultra low power, fan-less DM&P Vortex86DX- 800 MHz
image Supports 512MB(F SKU) /256MB(VE SKU) on-board DDR2 SDRAM memory
image Supports CRT+LCD dual independent display
image Supports 18/24-bit LVDS/TTL
image Supports 10/100 Ethernet
Embest
SBC-EC8800SBC-EC8800Single Board Computer
Buy NowBuy Now
The SBC-EC8800SBC-EC8800 is a single board computer designed around TI's high performance AM437X processor with an ARM Cortex-A9 core This 1GHz processor features 3D graphics capabilities for enhanced user interface and PRU-ICSS software for industrial ethernet protocols and position feedback control despite the compact body size the  SBC-EC8800SBC-EC8800 provides plenty of peripheral interface and connectivity options with gigabit Ethernet USB 2.0(host OTG LCD camera MicroSD card Wi-Fi Bluetooth(optional and DEBUG The on-board 80 pin(40 x 2 GPIO connector extends the signal interface possibilities even further to I 2C, UART, RGMII, SPI, MCASP, ADC, PWM, CAN, and RS485 interfaces. Features include:
image LCD interface supports up to 24bit LCD display (WXGA)
image Onboard MT41K256M16HA-125:E 1GB DDR3L device
image 4GB EMMC, 32MB QSPI and 32KB EEPROM onboard memory
image Supports Embest 4.3inch and 7inch LCD
image Supports 12-bit camera
image MicroSD card for storage extension
Avnet
MicroZed Evaluation Kit
Buy NowBuy Now
The MicroZedTm is a single board computer based on the Xilinx ZynqRegistered-7000 All Programmable SoC. It can be used as both a stand-alone evaluation board for basic SoC experimentation or combined with carrier card as an embeddable system-on-module (SOM). MicroZed contains 2 I/O headers that provide connection to 2 I/O banks on programmable logic (PL) side of ZynqRegistered-7000 AP SoC device. In stand-alone mode, these 100 PL I/O are inactive. When plugged into a carrier card, the I/O are accessible in a manner defined by the carrier card design. This combined stand-alone/SOM platform can quickly move a design idea from concept to production making MicroZed the ideal platform for SoC based applications. Features include:
image Xilinx XC7Z010-1CLG400C SoC
image 1GB of DDR3 SDRAM, 128Mb of QSPI flash, micro SD card interface
image 10/100/1000 Ethernet, USB 2.0, USB to UART communication
image 100 user I/O, configurable as up to 48 LVDS pairs or 100 single ended I/O
image 2x6 Digilent PmodRegistered compatible interface providing 8 PS MIO connections for user I/O
*Trademark. element14 is a trademark of AVNET. Other logos, product and/or company names may be trademarks of their respective owners.
  • element14 essentials
  • single board computers
  • microzed
  • Single Board Computer
  • raspberry pi 3 model b+
  • avnet
  • sbc
  • essentials
  • raspberry pi 3 b+
  • advantech
  • raspberry pi
  • BeagleBone
  • beaglebone black industrial
  • embest
  • beaglebone black wireless
  • BeagleBone Black
  • mp2100
    mp2100 over 8 years ago +1
    Nice list of existing SBC. The BB Black Industrial (? BB Red???) looks useful. When I tap on “add to cart”, most are not in stock. I realize not everything can be in stock at newark, but it hurts the instant…
  • mp2100
    Nice list of existing SBC.  The BB Black Industrial (? BB Red???) looks useful.  When I tap on “add to cart”, most are not in stock.  I realize not everything can be in stock at newark, but it hurts the instant gratification.
  • mp2100
