Essentials
  • Essentials
Essentials
Documents Related Components for element14 Essentials: Introduction to RF and End Launch Applications
  • Author Author: kabhari
  • Date Created: 1 May 2019 7:18 PM Date Created
  • Last Updated Last Updated: 1 May 2019 8:35 PM
  • Views 2201 views
element14 Learning Center
Sponsored byimage
The element14 ESSENTIALS of RF and End Launch Applications discusses RF communication fundamentals and some applications of end launch connectors. To extend the knowledge covered in the main module, this supplementary guide discusses the types of related components that can be used for products or prototyping.
Go to Learning Module
SMPM Coaxial, Straight Jack, Through Hole Vertical, 50 ohm
Buy NowBuy Now
The SMPM bullet adapter provides the same coveted blind mate functionality as the larger SMP size connectors, mitigating radial and axial misalignment with negligible change to VSWR and other signal losses. The SMPM-series is good for test equipment and racked electronics, where footprint space is a premium and mating boards together is difficult.
image 35% smaller than SMP connectors
image DC, up to 65 GHz
image Bullet adapter provides Blind Mate capabilities
image Available in PC mount, End Launch, and Cabled styles
image Manufactured with high-quality beryllium copper and brass
image Designed to meet MIL-PRF-39012 and MIL-STD-348 specifications
SMPM Coaxial, Straight Plug, Solder, 50 ohm
Buy NowBuy Now
The SMPM family includes PC mount and End Launch styles, straight/right-angled, .047 cabled connectors, and sealable flange mounts. All male connectors are offered as a full detent or smooth bore designs for your preference of separation forces.
1.85mm Coaxial, Edge Launch Jack, Solder, 50 ohm, Beryllium Copper
Buy NowBuy Now
The 1.85mm Screw On Board Edge, End Launch Jack is designed for use in a variety of applications while delivering signal integrity in demanding environments. Easy to assemble and disassemble to a PCB, they can be connected with solder or solderless, and adjustable to varying board thicknesses.
image Nickel-plated brass body
image Gold-plated beryllium copper contact
image White PTFE insulator
image Stainless steel bolt and washer
image Impedance: 50 ohm
image Typical VSWR 1.20-1.25
image Maximum frequency: 67 GHz
Round Contact, SMA Coaxial, Straight Jack, Board Edge / End Launch, 50 ohm
Buy NowBuy Now
The SMA Self-Fixture End Launch Jack Assembly with round contact attaches directly to a coplanar waveguide circuit board and operates up to 18 GHz with good return loss values. This enhanced end launch connector properly aligns and holds the center contact of a coaxial connector to the circuit board plane without the need for fixtures.
image Gold plated brass body
image Round female (socket) beryllium copper contact with gold plating
image PTFE insulator
image 50 Ohm impedance
image 0-18 GHz frequency range
image Working voltage 335 VRMS max. at sea, level Dielectric withstanding voltage 1000 VRMS min. at sea level
145-0701-802 -  End Launch Jack RF / Coaxial Connector, SMK Coaxial, Straight Jack, Screw, 50 ohm, Beryllium Copper
Buy NowBuy Now
The Johnson 2.92mm Connector provides an end launch solution for demanding applications requiring high frequency transmission. Although similar to the SMA interface, a smaller internal body diameter (2.92mm) and air dielectric provide a higher cutoff frequency.
image Performance to 40 GHz.
image Female contacts have a unique three-slot construction, which enhances connectivity by creating a more rugged connector while reducing the chance of intermittent connections.
image Connector mating interface per MIL-STD-348
image The plug connector VSWR is 1.20 Max to 40 GHz and a 12 inch SMK plug to plug cable assembly performs better than 1.35 VSWR to 40 GHz.
image The Field Replaceable Jacks are teamed with a high quality hermetic seal feed thru for use in sealed circuit modules.
image The 2.92mm plug interface employs more precise dimensions than an SMA and uses a shorter snub nose male pin such that the connector bodies align before the contacts engage.
SMA Coaxial, Straight Jack, Solder, 50 ohms, Beryllium Copper
Buy NowBuy Now
A straight SMA Coaxial Jack with gold-plated beryllium copper contact. This is used to transition microwave energy from coaxial to planar transmission line structures. This patent-pending connector provides a unique solution for microwave engineers who fabricate circuit designs on fragile high-frequency board substrates. The in-line connector design minimizes reflections as compared to a right-angle (perpendicular) pc mount transition.
image 1.05 + 0.02F (GHz) Maximum at 0 to 18GHz,
image 170VRMS Maximum at sea level, 45VRMS maximum at a 70K.ft working voltage
image 3mΩ (center) and 2mΩ (outer) Maximum contact resistance
image 500-cycle Minimum durability
image 7 to 10-inch.lbs Mating torque
Buy NowBuy Now
An RF/Coaxial Connector, SMA straight jack receptacle with gold plated brass body; gold-plated contact, printed circuit board style, solder termination type and Surface Mount.
image 50Ω Impedance
image 18GHz Maximum frequency
image 5000MΩ Minimum insulation resistance
image 500-cycle Minimum Durability
SMA Coaxial, End Launch Jack, Solder, 50 ohms, Beryllium Copper, .062” Board Thickness
Buy NowBuy Now
This end launch SMA RF Coaxial Connector is attached to the circuit board by inserting the board edge between the legs and soldering the legs and center conductor to pads on the board. For optimum high-frequency performance, the connector to circuit board transition must be adjusted for low VSWR. To compensate for the transition from coax to microstrip, trace widths "A" and "B" must be adjusted based on circuit board thickness. When properly adjusted, this technique yields a low VSWR over a wide bandwidth.
image Gold-plated finish
image Round contact
image 5000MΩ Insulation Resistance
SMA Coaxial, End Launch Jack with Thru Hole Terminals, 50 ohms, Beryllium Copper
Buy NowBuy Now
An RF/Coaxial Connector, SMA PC mount jack receptacle with gold plated brass body; gold-plated contact, printed circuit board style, solders termination type, and end launch mount. This high-frequency end launch connector is designed to attach directly to a high-frequency coplanar waveguide (CPW) circuit board transmission line, although other lines such as microstrip can be used with good results. These connectors can be used on high-frequency PC board substrate layers as thin as 10 MIL pin.
image 50Ω Impedance
image 26.5GHz Maximum frequency
End Launch, SMA Coaxial, Jack, Solder, 50 ohms, Beryllium Copper, .031” Board Thickness
Buy NowBuy Now
A straight SMA Coaxial Jack with gold-plated beryllium copper contact. It is attached to the circuit board by inserting the board edge between the legs and soldering the legs and center conductor to pads on the board. For optimum high-frequency performance, the connector to circuit board transition must be adjusted for VSWR.
image 335VRMS Working voltage
image 3mΩ Maximum initial contact resistance
image PTFE fluorocarbon per ASTM D 1710 and ASTM D 1457 insulators
*Trademark. Cinch Connectivity Solutions is a trademark of Bel Fuse Inc. Other logos, product and/or company names may be trademarks of their respective owners.
  • element14 essentials
  • related components
  • introduction to rf and end launch applications
