Essentials
  • Essentials
Essentials
Documents Related Components for element14 Essentials: Mechatronics
  • Author Author: pchan
  • Date Created: 29 May 2019 7:50 PM Date Created
  • Last Updated Last Updated: 29 May 2019 7:53 PM
  • Views 1282 views
element14 Learning Center
Mechatronics
Sponsored byimage
The element14 ESSENTIALS of Mechatronics is an introduction to mechatronics technology, including its processes, systems, and applications. This supplementary guide discusses the types of related components used.
Go to Learning Module
Development Boards
Stepper Motor Control EVM
Buy NowBuy Now
The KITXMC1300IFX9201TOBO1 is a stepper motor control shield based on Infineon's IFX9201 H-bridge and XMC1300 Series microcontroller. It is capable of driving two coils in a stepper motor in a dual-H-bridge configuration. Micro-stepping of the stepper motor can be achieved using internal comparators. Operational amplifiers adapt the motor current sense signal to the microcontroller's input levels.
image Compatible with Arduino Uno R3
image Capable of high performance current control
image Microstepping degree can be adjusted by software
image Overtemperature shut down with latch behaviour and undervoltage shut down of power section
XMC 750 Watt Motor Control Application Kit
Buy NowBuy Now
The XMC 750 Watt Motor Control Application Kit features a power board with an off-the-grid supply, input filter, active PFC, and high switching frequency IGBTs to turn on a 3-Phase drive. Both CPU Cards (XMC1300 and XMC4400 Drive Cards) provide galvanic isolation for the debug interface to guarantee safe operation during software development.
3 Phase Power Inverter 750W
image Power supply with line filter, NTC bypass relay and PFC circuitry
image 3 phase bridge realized with discrete IGBTs (IKD10N60R)
image PFC control via control IC (ICE3PCS02), MCU or disabled
Drive Card XMC1300
image XMC1302 (ARMRegistered CortexTm-M0-based) Microcontroller, 200 kByte on-chip Flash, TSSOP38
image 1 set of combined hall sensor and encoder interfaces
Drive Card XMC4400
image XMC4400 (ARMRegistered CortexTm-M4-based) Microcontroller, 512 kByte on-chip Flash, LQFP100
image 2 sets of combined hall sensor and encoder interfaces
image Multi feedback interface connectors for connection of resolver circuitry, UART, SPI, I2C, USB, etc.
XMC4800 Relax EtherCATRegistered Kit
Buy NowBuy Now
The XMC4800 Relax EtherCATRegistered Kit is assembled with an XMC4800 and a top-mounted XMC EtherCATRegistered Phy Board. It's a complete development kit for EtherCAT slave devices. The XMC4800 is powerful and functional enough to make the board an option for the development of EtherCATRegistered slaves such as servo drives and intelligent I/O devices.
image XMC4800-F144 MCU based on ARMRegistered CortexRegistered-M4 integrated EtherCATRegistered slave controller
image On-board debugger
image Power over USB
image ESD and reverse current protection
image Real time clock crystal
image Quad SPI flash, microSD card slot, Ethernet PHY and RJ45 jack
iMOTIONTm MADK platform (Power Board)
Buy NowBuy Now
The EVALM10565DTOBO1 is a power board, featuring  a complete power stage to drive a 3-phase motor powered by an IRSM505-065DA2 µIPM DIP. The IRSM505-065DA2 is a 2.6A, 500V Integrated Power Module (IPM) designed for advanced appliance motor drive applications such as energy efficient fans and pumps. The EVAL-M1-05-65D evaluation board is a part of the iMOTION Modular application design kit for drives (iMOTION MADK). It provides a single-phase AC-connector, rectifier, DC-link and 3-phase output for power.
image Power stage to drive 3-phase motor
image Standardized iMOTION MADK M1 platform interface
image 230V grid
image Emitter-shunts for current sensing and a voltage divider for DC-link voltage measurement
iMOTIONTm MADK platform (Control Board)
Buy NowBuy Now
The EVAL-M1-101T evaluation control board is a part of the iMOTIONTm Modular Application Design Kit for drives. The MADK platform is intended to use various power stages with different control boards. In order to run a motor, the mating power board is required to interface this evaluation board. It provides solutions for sensorless control of permanent magnet motors over the full speed range.
image Complete kit for running any permanent magnet motor via sensorless sinusoidal control
image 3.3V (default) or 5V VDD power supply
image Micro-USB connector and on-board debugger isolated by digital isolator
image Capable of 3-phase and type 3 of 2-phase modulation
image PCB size is 65 x 45 mm
Related Components
AURIXTm 32-bit microcontroller
Buy NowBuy Now
The TC275TP64F200NDCKXUMA1 is an Infineon AURIXTm microcontroller. Its multi-core architecture—based on up to six independent 32-bit TriCoreTm CPUs at 300 MHz—has been designed for safety and performance. Using the  AURIXTm scalable platform, developers can implement applications like motor control and drives, PLCs, or any other automation application. AURIXTm has enhanced communication capabilities to support communication between CAN, LIN, FlexRay and Ethernet buses.
image Up to six TriCoreTm  with up to 300 MHz per core and DSP functionality
image Supports floating point and fixed point with all cores
image Up to 6.9 MB of internal RAM and up to 16 MB of flash
image Follows SIL/ IEC61508 to support safety requirements up to ASIL-D
Motor Driver/Controller IC
Buy NowBuy Now
The IMC100 is a family of highly integrated ICs for the control of variable speed drives. It integrates both the required hardware and software to perform control of a permanent magnet synchronous motor (PMSM).
image Motion Control Engine (MCE) as a ready-to-use solution for variable speed drives
image Field oriented control (FOC) for permanent magnet synchronous motor (PMSM)
image Space vector PWM with sinusoidal commutation and integrated protection features
image Current sensing via single or leg shunt
image Sensorless operation
image Flexible host interface options for motor control commands: UART, PWM, or analog input signal
Motor Driver/Controller, Three Phase AC
Buy NowBuy Now
The IM818MCCXKMA1 is a component in the CIPOSTm Maxi IM818 product group used to control three phase AC motors and permanent magnet motors in variable speed drives applications such as low power motor drives (GPI, Servo drives), pumps, fan drives, and active filters for HVAC. It is also used in power applications that need good thermal performance and electrical isolation, as well as EMI and overload protection.
image Fully isolated Dual In-Line molded module
image 1200V TRENCHSTOPTm IGBT4
image Rugged 1200V SOI gate driver technology with stability against transient and negative voltage
image Integrated bootstrap functionality
image Built-in NTC thermistor for temperature monitor
image Under-voltage lockout at all channels
image Cross-conduction prevention
image Programmable fault clear timing and enable input
Half-Bridge Module, Motor Driver/Controller
Buy NowBuy Now
IRSM807-045MH is a 4A, 500V half-bridge module designed for advanced appliance motor drive applications such as energy efficient fans and pumps. IR's technology offers an extremely compact, high performance half-bridge topology in an isolated package. This advanced IPM offers a combination of IR's low RDS(on) Trench FREDFET technology and the industry benchmark half-bridge high voltage, rugged driver in a small PQFN package. At only 8x9mm and featuring integrated bootstrap functionality, the compact footprint of this surface mount package makes it suitable for applications that are space-constrained. IRSM807-045MH functions without a heat sink.
image Integrated gate drivers and bootstrap functionality
image Suitable for sinusoidal or trapezoidal modulation
image Low RDS(on) Trench FREDFET
image Under-voltage lockout for both channels
image Matched propagation delay for all channels
image Optimized dV/dt for loss and EMI trade offs
image 3.3V input logic compatible
image Active high HIN and LIN
image Isolation 1500VRMS min
System Basis Chip
Buy NowBuy Now
The TLE94613ESV33XUMA1 is a System Basis Chip featuring high integration and performance at an optimized cost for various automotive applications. It combines voltage supplies such as an LDO or DC-DC converter with up to 750mA, communication interfaces with CAN transceiver, a Flexible Data-Rate up to 5Mbit/s according to ISO 11898-2:2016, and LIN transceiver as well as supervision features (Wake input, Watchdog, Reset, Interrupt, Fail Output).
image Very low quiescent current consumption in Stop- and Sleep Mode
image Periodic Cyclic Wake in SBC Normal-, Stop- and Sleep Mode
image Low-Drop Linear Voltage Regulator 3.3 V, 150 mA (250 mA peak) for main supply
image Low-Drop Linear Voltage Regulator 5 V, 100 mA, protection feature for off-board usage
image High-Speed CAN transceiver supporting FD communication up to 5 Mbit/s and featuring CAN Partial
image Fully compliant to “Hardware Requirements for LIN, CAN and FlexRay Interfaces in Automotive Applications” Revision 1.3, 2012-05-04
image General Purpose High-Voltage in- and output (GPIO) configurable as Fail Output, Wake Input, Low-Side switch or High-Side switch
image High-Voltage Measurement function as alternate pin assignment
image Overtemperature and short circuit protection feature
image Wide input voltage and temperature range
Thyristor Module
Buy NowBuy Now
The TT162N14KOFHPSA1 is a 34 mm PowerBLOCK Thyristor Module for Phase Control. It is designed and assembled with highly reliable pressure contact technology using an isolated copper base plate.
image Industrial standard package
image Electrically insulated baseplate
image Fail safe
image Preventing arcing on fail
image Fuseless design possible due to high overload capability
eupecTm EconoBRIDGETm Thyristor Module
Buy NowBuy Now
The TDB6HK124N16RRBOSA1 is a eupecTm EconoBRIDGETm 1600V Half-Controlled Bridge Module with Brake Chopper and NTC for a more compact converter design.
image SCR Module Type: Bridge Rectifier, Three Phase – SCR
image 2.5 kV AC 1min Insulation
image Al2O3 Substrate with Low Thermal Resistance
image High Power Density
image High mechanical robustness
image Isolated copper base plate
image Solder Contact Technology
image RoHS compliant
Single Channel Photovoltaic Isolator
Buy NowBuy Now
The PVI5050NSPBF is a 1-channel 4-pin surface-mount Photovoltaic Isolator that generates an electrically isolated DC voltage upon receipt of a DC input signal. It is capable of directly driving gates of power MOSFETs or IGBTs. It utilizes a monolithic integrated circuit photovoltaic generator of novel construction as its output. The output is controlled by radiation from a gallium-aluminum-arsenide (GaAlAs) light emitting diode (LED), which is optically isolated from the photovoltaic generator. It is ideally suited for applications requiring high-current or high-voltage switching with optical isolation between the low-level driving circuitry and high-energy or high-voltage load circuits.
image Isolated voltage source
image Monolithic construction
image Solid-state reliability
image Up to 8µA output
Dual Channel Photovoltaic Isolator
Buy NowBuy Now
The PVI5033R Photovoltaic Isolator is a dual-channel, opto-isolated driver capable of directly driving gates of power MOSFETs or IGBTs. It utilizes a monolithic integrated circuit photovoltaic generator of novel construction as its output. The output is controlled by radiation from a gallium-aluminum-arsenide (GaAlAs) light emitting diode (LED) which is optically isolated from the photovoltaic generator. The PVI5033R is ideally suited for applications requiring high-current and/or high voltage switching with optical isolation between the low-level driving circuitry and high-energy or high- voltage load circuits.
image Employs a fast turn-OFF circuitry
image 1200VDC Output-to-output isolation
*Trademark. Infineon is a trademark of Infineon Technologies. Other logos, product and/or company names may be trademarks of their respective owners.
  • related components for element14 essentials
  • mechatronics
