Essentials
  • Essentials
Essentials
Documents Related Components for element14 Essentials: Secure MCUs for IoT Edge Applications
  • Author Author: kabhari
  • Date Created: 2 Jul 2019 6:49 PM Date Created
  • Last Updated Last Updated: 10 Jul 2019 4:38 PM
  • Views 839 views
element14 Learning Center
Sponsored byimage
The element14 ESSENTIALS of Secure MCUs for IoT Edge Applications discusses the purpose, function, and challenges of edge applications, and will introduce you to the LPC5500 Series of Microcontrollers.  To extend the knowledge covered in the main module, this supplementary guide discusses the types of related components that can be used for products or prototyping.
Go to Learning Module
Development Board
LPCXpresso55S69 Development Board
Buy NowBuy Now
The LPCXpresso55S69 development board provides the ideal platform for evaluation of and development with the LPC55S6x MCU based on the ArmRegistered CortexRegistered-M33 architecture. The board includes a high performance on-board debug probe, audio subsystem and accelerometer, with several options for adding off-the-shelf add-on boards for networking, sensors, displays and other interfaces.
The LPCXpresso55S69 is fully supported by the MCUXpresso suite of tools, which provides device drivers, middleware and examples to allow rapid development, plus configuration tools and an optional free IDE. MCUXpresso software is compatible with tools from popular tool vendors such as Arm and IAR, and the LPCXpresso55S69 may also be used with the popular debug probes available from SEGGER.
image Onboard, high-speed USB, Link2 debug probe with CMSIS-DAP and SEGGER J-Link protocol options
image UART and SPI port bridging from LPC55S69 target to USB via the onboard debug probe
image Hardware support for external debug probe
image 3 x user LEDs, plus Reset, ISP (3) and user buttons
image Micro SD card slot (4-bit SDIO)
image NXP MMA8652FCR1 accelerometer
image Stereo audio codec with a line in/out
image High and full speed USB ports with micro A/B connector for the host or device functionality
Related Components
LPC55S66JBD100K - ARM CORTEX-M33, QDDKEY/PUF, Flash256 KB; SRAM 144 KB
Buy NowBuy Now
The LPC55S6x is an ARM Cortex-M33 based microcontroller for embedded applications. These devices include an ARM Cortex-M33 coprocessor, CASPER Crypto/FFT engine, PowerQuad hardware accelerator for DSP functions, up to 320 KB of on-chip SRAM, up to 640 KB on-chip flash, PRINCE module for on-the-fly flash encryption/decryption, high-speed and full-speed USB host and device interface with crystal-less operation for full-speed, SD/MMC/SDIO interface, five general-purpose timers, one SCTimer/PWM, one RTC/alarm timer, one 24-bit Multi-Rate Timer (MRT), a Windowed Watchdog Timer (WWDT), nine flexible serial communication peripherals (which can be configured as a USART, SPI, high speed SPI, I2C, or I2S interface), Programmable Logic Unit (PLU), one 16-bit 1.0 Msamples/sec ADC, comparator, and temperature sensor.
image Architecture: ARM Cortex-M33
image No. of Bits: 32bit
image CPU Speed: 100MHz
image Program Memory Size: 256KB
image RAM Memory Size: 144KB
image No. of Pins: 100Pins MCU
image Case Style: HLQFP
image No. of I/O's: 64I/O's
image Embedded Interface Type: I2C, I2S, SPI, UART, USB
image Supply Voltage Min: 1.8V
image Supply Voltage Max: 3.6V
LPC55S66JET98K - 32-BIT ARM CORTEX-M33, QDDKEY/PUF TRAY MULTIPLE; Flash256 KB; SRAM 144 KB
Buy NowBuy Now
image Arm Cortex-M33 core
image Co-processor
image On-chip memory
image Security features
image Serial interfaces
image Impedance: 50 ohm
image Typical VSWR 1.20-1.25
image Maximum frequency: 67 GHz
LPC55S69JBD100K - ARM CORTEX-M33, QDDKEY/PUF; Flash 640 KB; SRAM 320 KB
Buy NowBuy Now
image Program Memory Size: 640KB
image RAM Memory Size: 320KB
image MCU Case Style: HLQFP
LPC55S69JET98K - 32-BIT ARM CORTEX-M33, QDDKEY/PUF TRAY MULTIPLE; Flash 640 KB; SRAM 320 KB
Buy NowBuy Now
image Co-processor
image Digital peripherals
image Analog peripherals
image Timers
image Clock generation
image Power-saving modes
*Trademark. NXP is a trademark of NXP Inc. Other logos, product and/or company names may be trademarks of their respective owners.
  • iot edge applications
  • secure mcus for iot edge applications
  • related components for element14 essentials
  • nxp microcontrollers
