Essentials
  • Essentials
Essentials
Documents Related Components for element14 Essentials: Sealed Connectors
  • Author Author: pchan
  • Date Created: 27 Aug 2019 8:02 PM Date Created
  • Last Updated Last Updated: 20 Sep 2019 4:12 PM
  • Views 874 views
element14 Learning Center
Connectors IV: Sealed Connectors
Sponsored byimage
The element14 ESSENTIALS of Sealed Connectors covers the concepts, characteristics, and design of sealed connectors used in space-constrained applications, and introduces you to the Molex Squba Wire-to-Wire connectors.
Go to Learning Module
Related Components
204220-0008 - Connector Housing, Receptacle, 8 Positions, 1.8 mm
Buy NowBuy Now
A 1.80mm Pitch, 8-Circuit, Single Row, Sealed Receptacle Assembly used in a wide range of space-constrained applications. Features include:
image Application: Signal, Wire-to-Wire
image Circuits: (maximum) 8
image Flammability: 94V-0
image Gender: Receptacle
image Material: Resin Nylon
image Pitch - Mating Interface 1.80mm
image Temperature Range: -40°C to +105°C
image Environmental: IP67
204301-0001 -  Tin Plated Socket Contact, 22 AWG
Buy NowBuy Now
A Receptacle Crimp Terminal with Matte Tin Plating that fits 22-24 AWG wire. Features include:
image Physical Durability: (mating cycles max) 10
image Gender: Female
image Material: Metal Copper Alloy
image Plating Mating: Matte Tin
image Plating Termination: Matte Tin
image Plating min Mating: 2.500μm
image Plating min Termination: 2.500μm
image Termination Interface: Style Crimp or Compression
image Wire Insulation Diameter: 0.95mm-1.40mm
image Wire Size: AWG 22, 24
image Current - Maximum per Contact: 6.0A
image Voltage - Maximum: 125V
204223-0006 -  Connector Housing, IP67, Squba 204223 Series, Plug, 6 Ways, 1.8 mm
Buy NowBuy Now
A 1.80mm Pitch, 6-Circuit, Single Row, Squba Sealed Plug Assembly used in a wide range of space-constrained applications. Features include:
image Circuits (maximum): 6
image Gender: Plug
image Number of Rows: 1
image Pitch - Mating Interface: 1.80mm
image Pitch - Termination Interface: 1.80mm
image Temperature Range - Operating -40°C to +105°C
45145-0210 -  Cable Assembly, Squba Receptacle to Squba Receptacle, 2 Positions, 1 meter
Buy NowBuy Now
A Single Row, 1.0m, 2-Circuit, Squba-to-Squba Off-the-Shelf (OTS) Receptacle Cable Assembly used to facilitate both prototyping and global production. Features include:
image Application: Power, Signal
image Assembly Configuration: Dual Ended Connectors
image Connector to Connector: Squba-to-Squba
image Cable Length: 1.0m
image Circuits (Loaded): 2
image Gender: Female-Female
image Material - Plating: Mating Matte Tin
image Material - Plating: Termination Matte Tin
image Plating min - Mating: 2.500μm
image Plating min - Termination: 2.500μm
image Single Ended: No
image Wire/Cable Type: UL 1061
image Current - Maximum per Contact: 5.0A
204220-0010 -  Receptacle Connector Housing, IP67, 10 Positions, 1.8 mm pitch
Buy NowBuy Now
A 1.80mm Pitch, 10-Circuit, Single Row, Squba Sealed Receptacle Assembly used in a wide range of space-constrained applications. Features include:
image Circuits (maximum): 10
image Lock to Mating Part: Yes
image Polarized to Mating Part: Yes
image Temperature Range - Operating: -40°C to +105°C
204226-1001 -  Tin Plated Contact Pin, Crimp, 22 AWG
Buy NowBuy Now
A Squba Plug Terminal featuring Matte Tin Plating that fits 22-24 AWG wire. Features include:
image Physical Durability (mating cycles max): 10
image Gender: Male
image Material - Metal: Copper Alloy
*Trademark. MolexRegistered is a trademark of Molex Corporation. Other logos, product and/or company names may be trademarks of their respective owners.
  • molex
  • sealed connectors
  • essentials
  • squba
  • sealed_connectors
