Essentials
  • Essentials
Essentials
Documents Related Components for element14 Essentials: Circuit Protection III
  • Author Author: pchan
  • Date Created: 23 Sep 2020 10:21 PM Date Created
  • Last Updated Last Updated: 5 Oct 2020 5:25 PM
  • Views 1404 views
element14 Learning Center
essentials logo
Circuit Protection III: Surge Protection
Sponsored bysponsor logo
The element14 ESSENTIALS of Surge Protection focuses on the fundamentals, theories, applications, and technologies related to power surge protection. To extend the knowledge covered in the main module, this supplementary guide discusses the types of related components used for product or system development.
Go to Learning Module
Surge Protectors
OVR T1-T2 12.5-275S C QS MAINS SURGE PROTECTOR, 275VAC, DIN RAIL
Buy NowBuy Now
image Suppressor Type: Mains Surge Protector
image No. of Poles: 1 Pole
image SPD Type: Type 1 & 2
image Peak Surge Current: 80kA
image Continuing Operating Voltage Max: 275VAC
image Suppressor Mounting: DIN Rail
image Product Range: OVR Series: designed to prevent electrical systems and equipment against transitory surges and impulses caused by lightning and operations on the electrical grid.
image Discharges the surge coming from lightning events (direct & indirect impacts) or from switching operations
image Limits the peak of voltage to an acceptable level for the end equipment
image Increases the quality of service and equipment lifespan
image Complete range of Surge Protective Devices for all applications: low-voltage power, data, telecom, CCTV PV, WT, LED and self-protected
image Fully equipped: End of life indicator, safety reserve system, pluggable, auxiliary contacts
image Range available for all electrical networks (TT, TNC, TNS, IT)
product image
OVR T1-T2 3L 12.5-275S P TS QS MAINS SURGE PROTECTOR, 275VAC, DIN RAIL
Buy NowBuy Now
image No. of Poles: 3 Pole
image Product Range: OVR Series designed to prevent electrical systems and equipment against transitory surges and impulses caused by lightning and operations on the electrical grid.
product image
OVR CAT-5E ENET SURGE PROTECTOR, 1PORT, PANEL
Buy NowBuy Now
image Suppressor Type: Ethernet Surge Protector
image No. of LAN Ports (Input): 1 Port
image Peak Surge Current: 10kA
image Suppressor Mounting: Panel
image Description: OVR CAT-5E DATA SPD FOR CAT-5E 100 BASET COMPUTER NETWORKS
image Dimensions (w x d x h): 240 mm x 106 mm x 60 mm
image Product Net Weight: 0.15 kg
product image
OVR SL50 DATA/SIGNAL LINE PROTECTOR, 2P, DIN RAIL
Buy NowBuy Now
image OVR SL50 Surge Protective Device
image Description: OVR SL06 SLIM LINE 6V DATA SPD FOR 2 WIRE SIGNAL LINES UP TO 750mA CURRENT
image Connection Type: Screw Clamp
image Discharge Current: I (max, 8 / 20 µs) 10 kA
image Maximum Continuous Operating Voltage (Uc):56.7 V
image Nominal AC Voltage of the System (Uo):50 V
image Number of Protected Poles: 3
image Product Main Type: Data SPD
image Product Name: Surge Protective Devices
image Rated Current (In):750 mA
image Rated Frequency (f):45 MHz
image Standards: IEC 61643-21
image Suitable to protect systems against transient overvoltages or surges from lightning and electrical switching events
image  Voltage Protection Level ( Up):68.3 V
product image
OVRPV401500HPTSU AB OVRPV401500HPTSU OVR PV DIN SPD
Buy NowBuy Now
image OVR PV 40-1500H P U
image Description: OVR PV 40-1500H P U Surge Protective Device
image Number of Protected Poles: 2
image Arrester Class: II
image Product Main Type: T2
image Standards: UL 1449 Ed3
image Version: Plug-in
image Discharge Current: Nominal 10 kA; Maximum 40 kA
image Impulse Current: I (imp, 10 / 350 µs) 2 kA
image Voltage Rating DC:1500 V
image Voltage Protection Level (Up):(L-N) 4.5 kV
image (N-PE) 4.5 kV
image (L-PE) 4.5 kV
image Short Circuit Withstand Icc:10 kA
image Suitable to protect systems against transient overvoltage (lightning)
image  Dimensions (w x d x h): 53.4 mm x 58 mm x 88 mm
*Trademark. ABB is a trademark of ABB Ltd. Other logos, product and/or company names may be trademarks of their respective owners.
  • surge_protectors
  • circuit protection iii
  • abb
  • surge protection
