Essentials
  • Essentials
Essentials
Documents Related Components for element14 Essentials: Sensors VI
  • Author Author: vijeth_ds
  • Date Created: 23 Dec 2020 11:31 AM Date Created
  • Last Updated Last Updated: 31 Dec 2020 8:18 PM
  • Views 1456 views
element14 Learning Center
Sensors VI: Automotive Sensor for EV/HEV Applications
Sponsored byimage
The element14 ESSENTIALS of Automotive Sensors for EV/HEV Applications covers sensor technology used in automotive applications, ranging from hybrid electric vehicles (HEVs) to fully electric vehicles (EVs). To extend the knowledge covered in the main module, this supplementary guide discusses the types of related components used for prototyping or product development.
Go to Learning Module
Airflow Sensor
FMA-500-T1-40W-GV Air Flow Sensor, FMA Series, Filtration Air Restriction, Analog, 1/8-27 NPT, 40in H2O, Vacuum Gage
Buy NowBuy Now
The NovaSensor FMA Series of Filtration Air Restriction (FAR) Sensor accurately measures the pressure loss across a variety of air filtration devices, utilizing high accuracy NPA piezoresistive technology in a low-profile form factor that is easy to install and maintenance-free. Available in multiple positive or vacuum pressure ranges, mating with an integrated AMPSEAL 16 (3-way) electrical connector and 1/8-27 NPT female pressure connection port.
image Supply Voltage: 5VDC
image Linear Output: 0.5V to 4.5V (Ratiometric)
image Diagnostic Features (Bridge Connection Checks, Bridge Short Detection, Power Loss Detection)
image Temperature-compensated
image Sealed AMP Electrical Connector
image Multiple Pressure Ranges Available (Vacuum and Pressure)
image Fast Response Time
image REACH & RoHS Compliant
Battery Coolant Temperature Sensor
WTF0803B001 RTD Sensor, -40 °C, 100 °C, 2.828 kohm
Buy NowBuy Now
The Coolant Temperature Sensor (CTS) monitors the temperature of the coolant that is being pumped around the battery to cool the battery module of EVs/PHEVs. If the battery module starts to overheat, the Coolant Temperature Sensor relays a signal to the Battery Management System (BMS). The BMS uses this information to prevent battery packs from any damage and maximize performance.
image Integral connector with compact size
image Existing field-proven design
image Alternate RvT curves and terminal plating available
image Various dimensions to meet package requirements
Engine Temperature Sensor
GE-1711ATM Temperature Sensor, Engine, -40°C to 180°C, 10 kohm, 3977 K, Brass, Amphenol Sine ATM Connector
Buy NowBuy Now
The Thermometrics GE-1711 / GE-1797 Engine Temperature Sensor (ETS) monitors the temperature of the coolant, oil, or fuel being used in an engine. Their purpose is to provide a signal output that is proportional to engine temperature. This signal can be used as an input to a temperature gauge, provide input to an Engine Control Unit (ECU), or control a cooling fan circuit.
image High accuracy and long-term stability
image Fast response time
image Pigtail connector
image Alternative RvT curves possible
image Different connection systems to meet package requirements
image 180°C max operating temperature
image Both brass and stainless steel configurations available, depending on media/interface/environment
image Other resistance and beta values possible
image RoHS compliant
Gas Detection Sensor
T3031-2-2K-24-P Gas Detection Sensor, Harsh Environment, Carbon Dioxide, 2000 ppm, 5 %
Buy NowBuy Now
The Telaire T3030 Series is a range of Carbon Dioxide (CO2) Sensor designed to meet the specific needs of customers who require measuring CO2 in harsh or difficult environments. Based on a series of modules, the casing offers a number of combinations to meet the needs of range, supply voltage, and output type in various applications. Example applications include buses, refrigerators, subway stations, and railway carriages, and more.
image Accurate Carbon Dioxide (CO2) Transmitter for HVAC control applications
image Easy mount with 2 external tabs
image Rated up to IP67 (build dependent)
image Available with potting
image Different calibrations available up to 20% CO2 concentration
image Analog or digital output options
image Non-Dispersive Infrared (NDIR) measuring technology
image Shipped factory-calibrated
image Accuracy for 10-year life
image Extended operating temperature range
Inductive Position Sensor
PSC360G2-F1A-C0000-ERA360-RE-K Magnetic Position Sensor, PSC-360 Series, Rotary, Flat Shaft, Simple Output, Analog, 360 °, 30 Vdc
Buy NowBuy Now
The PSC-360 is a high performance non-contacting rotary position sensor for automotive, off-road, marine, medical and industrial applications without the limitations of potentiometric solutions (e.g., wear, limited electrical angles). A configurable switch output, as an option, integrated within the sensor is available too. Redundancy can be achieved by employing a dual die version providing independent voltage outputs with fully customized characteristics providing the possibility to detect error outputs by the host electronics. Sealed for harsh environments and flange mounted for easy positioning when necessary, it provides high stability under harsh environment conditions such as vibration, shock, extreme temperatures, humidity, dither, moisture, or dirt. Available with fly leads, it can be customized to customer´s needs to any desired connector configuration.
image Simple and robust magnetic design
image High resolution (up to 14-bit)
image Ratiometric analog or PWM outputs
image Absolute position feedback up to 360º (keeps position on power loss)
image True full redundant version
image Sealed construction for harsh environments such as off-highway and marine
image Protected from dust, moisture, vibration and extreme temperatures
image Endless rotation
image Fully programmable transfer function output at the factory with electrical outputs up to 360º
image Self-diagnostic features
image Over voltage protection and reverse voltage protection
image Extended voltage input supply values
Motor Coil Temperature Sensor
A-1737A-1737 Temperature Sensor, Motor Coil
Buy NowBuy Now
The Thermometrics A-1737A-1737 Motor Coil Temperature Sensor is used on a starter generator to provide temperature measurement of the motor coil. Typically mounted on the neutral bar, it detects increases in current that would indicate a failure that could lead to a stall. The sensor can also be used to monitor the motor windings temperature and warn of an over-temperature conditions.
image High accuracy and long term stability
image Existing field proven design
image Weld connections covered by PTFE Heat Shrink
image Meets the temperature and vibration demands of EV and HEV traction motors
image Alternate RvT (resistance versus temperature) curves available
image Custom packages available to meet various motor configurations
image A variety of terminal and connector options
Pressure Sensor
NPI-19A-100GV Pressure Sensor, 100 psi, Voltage, Gauge, 10 VDC, O-Ring Seal
Buy NowBuy Now
The NovaSensor NPI-19 Series of Medium Pressure Sensor consists of current-driven, media-isolated pressure Sensors, incorporating state-of-the-art IsoSensor technology. They are designed to operate in hostile environments while still providing the outstanding sensitivity, linearity, and hysteresis of a silicon sensor.
The piezoresistive sensor chip is housed in a fluid-filled cylindrical cavity and isolated from measured media by a stainless steel diaphragm and body. As with all NovaSensor silicon Sensor, the NPI Series employs SenStableRegistered processing technology, providing excellent output stability.
The modular design allows for a variety of pressure port modules, which are hermetically welded to the sensor header module. To compensate for temperature effects, a complete resistor network is supplied on a hybrid ceramic substrate. The IsoSensor design minimizes temperature errors to provide a maximum offset error of 0.75% FSO over the 32°F to 158°F (0°C to 70°C) compensated range.
image Solid state, high reliability
image 316L stainless steel, ISO sensor design
image ±0.5% static accuracy
image Temperature compensated 32°F to 158°F (0°C to 70°C)
image High sensitivity, 100 mV FSO with 1.0 mA excitation
image Linearity 0.1% FSO typical
image Four standard ranges: 0 to 15 psig (0 to 1 bar), 0 to 250 psig (0 to 17 bar) available in gauge or absolute
image Voltage driven ranges: 15, 30, 50, 100, 200 and 300 psi (1, 2, 3, 7, 14 and 20 bar) gauge and absolute
image Standard configurations include:
  • 1/2 in-20 UNF threaded male port with 1.0 in (25 mm) flange
  • 0.74 in (18.8 mm) diameter x 0.28 in (7 mm) long cylinder with o-ring seals
  • 1/4 in-18 NPT male port with 7/8 in (22 mm) flange
  • 1/8 in-27 NPT male port with 7/8 in (22 mm) flange
image Custom configurations and other pressure ranges available.
Thermistor
CL-30 Thermistor, ICL NTC, 2.5 ohm, -25% to +25%, Radial Leaded, CL Series
Buy NowBuy Now
The Thermometrics CL Series of Inrush Current Limiting Thermistors consists of a disc thermistor with uninsulated lead-wires, and are used to control inrush current when switching power supplies. The main purpose of limiting inrush current is to prevent components in series with the input to the DC/DC converter from being damaged. Typically, inrush protection prevents nuisance blowing of fuses or breakers as well as welding of switch contacts.
image Low cost, solid state device for inrush current suppression
image Excellent mechanical strength
image Wide operating temperature range: -58°F to 347°F (-50°C to 175°C)
image Suitable for PCB mounting
image Available as a standard with kinked or straight leads and on tape and reel to EIS RS-468A for automatic insertion
image Low steady resistance and accompanying power loss
image Small size
image Low cost solid state sensor
*Trademark. Amphenol is a trademark of Amphenol Corp. Other logos, product and/or company names may be trademarks of their respective owners.
  • sensors
  • automotive_sensors_for_evhev_applications
  • essentials
  • amphenol
  • ev_hev_applications
