Essentials
  • Essentials
Essentials
Documents Related Components for element14 Essentials: Automation IV
  • Author Author: pchan
  • Date Created: 17 May 2021 3:27 PM Date Created
  • Last Updated Last Updated: 20 May 2021 7:14 PM
  • Views 1795 views
element14 Learning Center
Automation IV: PLC and Ladder Logic Programming Related Components
Sponsored byimage
The element14 ESSENTIALS of PLC and Ladder Logic Programming the basics of PLC, including hardware structure, programming language, and use cases. To extend the knowledge covered in the main module, this supplementary guide discusses the types of components used for automation or system control.
Go to Learning Module
EASY-BOX-E4-DC1 Eaton Easy Nano Programmable Logic Controller, Starter set
Buy NowBuy Now
Starter package consisting of EASY-E4-DC-12TC1, patch cable and software license for easySoft. The easyE4 device is a programmable switching and controller device that is used to replace relay and contactor controls. It is intended exclusively for monitoring, operating, and controlling machines and systems, as well as building and automation services for commercial buildings.
image No. of Inputs: 8
image No. of Outputs: 4
image Current Rating: 500mA
image Supply Voltage Max: 28.8VDC
EASY-E4-DC-6AE1 - I/O expansion, For use with easyE4, 24 V DC
Buy NowBuy Now
Input/output extension for easyE4 control relay. Expandable with the easyE4 series of digital input/output expansions with easy-E4-CONNECT1 connector (Item Y7-197225)
image Rated operating voltage: 24V DC
image Analog inputs: 4
image Analog outputs: 2
image Screw terminals
EASY512-AC-REASY512-AC-R easy Programmable Relays, Control Rel Relay, Includes display, 240 Vac, 8 digital input, 4 relay output
Buy NowBuy Now
easy500 programmable logic controller is ideal for controlling small applications with up to 12 I/O signals. Models are available with and without displays. Front panel programming eliminates the need to change wiring and wiring diagrams, increasing the savings realized.
image No. of Digital Inputs: 8
image No. of Digital Outputs: 4
image Meter Display Type: LCD
image IP / NEMA Rating: IP20
image Product Range: easy500 Series
EASY-E4-DC-4PE1 - I/O expansion, For use with easyE4, 24 V DC, Inputs
Buy NowBuy Now
easyE4 Input/Output expansions with temperature detection.
image Analog inputs: 4 with temperature sensors PT100, PT1000 or Ni1000
image Display with diagnostic LED
image Software EASYSOFT-SWLIC/easySoft 7
image Supply voltage: 24 V DC
EASY-E4-UC-12RCX1 CONTROL RELAY W/LED, 24VDC/VAC
Buy NowBuy Now
Expandable with the easyE4 series of digital input/output expansions with easy-E4-CONNECT1 connector (Item Y7-197225).
image Rated operating voltage 12V DC, 24V DC or 24V AC
image 8 digital inputs, No. of these can be used as analog inputs - 4
image Digital outputs: 4 relays
image Delivery with customized user program is possible via Item (Y7) -2010781 EASYCOMBINATION
EASY-E4-UC-16RE1 Eaton Easy Nano Programmable Logic Controller Expansion Device, Easy E4 Expansion Device, Digital Input/ Output 12/24 V DC, 24 V AC, Screw Terminal
Buy NowBuy Now
image Rated operating voltage: 12V DC, 24V DC or 24V AC
image Digital inputs: 8
image Digital outputs: 8 relays
*Trademark. Eaton is a trademark of Eaton Corp. Other logos, product and/or company names may be trademarks of their respective owners.
  • plc
  • related_components
  • eaton
  • essentials
  • programmable_logic_controller
  • automation
