Essentials
  • Essentials
Essentials
Documents Related Components for element14 Essentials: Connectors VII
  • Author Author: pchan
  • Date Created: 30 Jun 2021 2:59 PM Date Created
  • Last Updated Last Updated: 1 Jul 2021 4:58 PM
  • Views 1869 views
element14 Learning Center
Connectors VII: Flat Flexible Cables (Premo-Flex) and Interconnections
Sponsored byimage
The element14 ESSENTIALS of Flat Flexible Cables (Premo-Flex) and Interconnections Circuits and Interconnections discusses the benefits of flexible circuits and interconnects, including the types of flexible interconnects, their benefits, and applications. To extend the knowledge covered in the main module, this supplementary guide discusses the types of related components used for prototyping or product development.
Go to Learning Module
Flat Flexible Cable
15014-0421 FFC / FPC Cable, 21 Conductor, 0.25 mm, Same Sided Contacts, 4", 101.6 mm, Brown, Orange
Buy NowBuy Now
Standard 0.25mm pitch Premo-Flex jumpers mate with Molex 0.25mm pitch Easy-On FFC/FPC connectors to offer reliable connectivity in a compact design for tight packaging applications. Typical applications include medical, smart phones and mobile devices, consumer data/computing and automotive applications.
image Mates with 0.25mm pitch Easy-On FFC/FPC connectors (series 502078, 503300, 503320)
image Simple assembly process
image Ideal for electrical connections between PCBs, display boards and more
image Offers super fine pitch for space constrained applications
image Provides design flexibility and fast availability
image 0.2A maximum current, 9µA dielectric withstanding voltage
image Insulation resistance of >50Gohm
image Temperature range from -40 to +105°C
image Conductor material is copper, gold plating, 0.018mm nominal thickness
image Insulation tape material is polyimide and flame retardant adhesive, orange-brown color
15166-0321 FFC / FPC Cable, 30 Conductor, 0.5 mm, Same Sided Contacts, 4", 102 mm, White
Buy NowBuy Now
Standard 0.50mm pitch Premo-Flex jumpers mate with Molex 0.50mm pitch Easy-On FFC/FPC connectors to offer reliable connectivity in a compact design for tight packaging applications. Typical applications include medical, smart phones and mobile devices, consumer data/computing and automotive applications.
image Mates with 0.50mm pitch Easy-On FFC/FPC connectors (Mates With 524353033, 541043033, 524373033, 541323033, 5019513000)
image 0.5A maximum current
98267-043198267-0431 Cable Assembly, 26 Core, 152 mm, white
Buy NowBuy Now
1.00mm Pitch Premo-FlexTm FFC Jumper, Same Side Contacts (Type A), 26 Circuits, 0.152m Cable Length, 0.22mm Cable Thickness, Tin (Sn) Plating
image Contact area can be configured on the same or opposite sides of the flexible cable jumper
image Rated up to +105°C
image Ultra-thin, ultra-flexible 0.12mm FFC jumper
image 0.30mm pitch etched polyimide jumpers in cable termination thickness of 0.12mm
15023-0841 FFC / FPC Cable, 41 Core, 0.5 mm, Same Sided Contacts, 203 mm
Buy NowBuy Now
0.50mm Pitch Premo-Flex LVDS Jumper, 203.00mm Cable Length, Gold (Au) Plating, 41 Circuits
image Cable Length: 203.00mm
image Circuits (Loaded): 41
image Contact Layout: Type A (same side)
image Material - Outer Jacket Polyester
image Material - Plating Mating Gold
image Pitch - Mating Interface: 0.50mm
image Temperature Range: Operating -40° to +80°C
image Current Maximum per Contact 0.5A
image Voltage Maximum 30V AC
15014-0417 FFC / FPC Cable, 17 Core, 0.25 mm, Same Sided Contacts, 101.6 mm, Brown, Orange
Buy NowBuy Now
image Insulation tape material is polyimide and flame retardant adhesive, orange-brown colour
15022-2450 FFC / FPC Cable, 50 Core, 0.5 mm, Same Sided Contacts, 610 mm
Buy NowBuy Now
0.50mm Pitch Premo-Flex LVDS Jumper, 610.00mm Cable Length, Gold (Au) Plating, 50 Circuits
image Cable Length: 610.00mm
image Circuits (Loaded): 50
15166-011915166-0119  FFC / FPC Cable, Premo Flex Jumper, 12 Core, 0.5 mm, Same Sided Contacts, 2 ", 51 mm, White
Buy NowBuy Now
0.50mm Pitch Premo-Flex FFC Jumper, Same Side Contacts (Type A), 12 Circuits, 0.05m Cable Length, Tin (Sn) Plating
image Cable Length 0.051m
image Circuits (Loaded) 12
image Circuits (maximum) 12
image Net Weight 1.000/g
image Packaging Type Bag
image Pitch - Termination Interface 0.50mm
image Temperature Range - Operating -40° to +105°C
image Wire Size AWG N/A
image Wire/Cable Type Flat Flex Cable
image Electrical
image Current - Maximum per Contact 0.5A
image Voltage - Maximum 60V AC
15018-0567 FFC / FPC Cable, 60 Conductor, 0.5 mm, Same Sided Contacts, 6 ", 152 mm, Ears
Buy NowBuy Now
0.50mm Pitch Premo-Flex FFC Jumper, Same Side Contacts (Type A), 60 Circuits, 152.00mm Cable Length, Gold (Au) Plating, with Ears
image Cable Length 152.00mm
image Circuits (Loaded) 60
image Net Weight 3.630/g
image Pitch - Mating Interface 0.50mm
image Electrical
98266-032698266-0326 FFC / FPC Cable, Premo Flex Jumper, 30 Core, 0.5 mm, Opposite Sided Contacts, 6 ", 152 mm, White
Buy NowBuy Now
0.50mm Pitch Premo-Flex FFC Jumper, Opposite Side Contacts (Type D), 30 Circuits, 0.152m Cable Length, Tin(Sn) Plating
image Cable Length 0.152m
image Circuits (Loaded) 30
image Net Weight 1.481/g
image Electrical
15015-042715015-0427 FFC / FPC Cable, Premo Flex Jumper, 27 Core, 0.3 mm, Same Sided Contacts, 4 ", 101.6 mm
Buy NowBuy Now
0.30mm Pitch Premo-Flex Etched Copper Polyimide Jumper, Same Side Contacts (Type A), 0.102m Cable Length, 27 Circuits
image Cable Length 0.102m
image Circuits (Loaded) 27
image Circuits (maximum) 27
image Pitch - Termination Interface 0.30mm
image Electrical
image Current - Maximum per Contact 0.2A
image Voltage - Maximum 50V AC/DC
*Trademark. Molex is a trademark of Molex Corporation. Other logos, product and/or company names may be trademarks of their respective owners.
  • connectors
  • molex
  • related components for element14 essentials
  • premo-flex
  • flat_flexible_cables
  • flat_flexible_cables_(premo-flex)_and_interconnections
