STEM Academy
STEM Academy
Blog Temperature Sensing with the Raspberry Pi and Google
  • Author Author: mikedavis
  • Date Created: 5 Mar 2015 1:07 PM Date Created
  • Views 1124 views
  • gspread
  • temperature
  • raspberrypi
  • stem space
mikedavis
mikedavis
5 Mar 2015
A while ago, I posted an instruction sheet for temperature sensing with the waterproof DS18B20 probe.  At the time, I was really interested in how quickly my coffee would cool off depending on the kind of cup I was using.
The program I used involved a gspread library for a python program.  My problem was that I had an easy time getting temperatures, but I had a hard time getting them into some kind of file where I could save them and do some work later.  Finding gspread was excellent, because it did two things for me.  First, it saved my temperatures into a Google Spreadsheet that I could access from anywhere in the world.  That was very handy.  Second, it gave me the confidence that the probe was actually working.  If I checked and saw a recent temperature, I knew things were working.
My problem, as I knew (and pointed out by @Charles Turner) if the program ever hung up, an infinite loop would take over, and that would be the end of the temperature sensing and logging.
It was recommended that I made the program something that would execute just once, and then have crontab make it a repetitive action.  So now, my program executes every two minutes, and logs a temperature into my Google Spreadsheet.  I have been using it to monitor the temperature in my classroom, and I have posted it to our class website (Mike Davis Chemistry).
I will do a more detailed blog post and set of instructions very soon.  In the meantime, I was just so pleased with how well this worked, that I wanted to share it.  I also wanted to thank the community for helping me get over a problem.
Check out the temperature of room 3831 at Truman College here.  (https://docs.google.com/spreadsheets/d/1mccAri0TsLIVCXKzzrx8lxO7JXAAdm6i6FmboO75wjE/edit?usp=sharing) or follow it here.
  • d6diesel
    d6diesel over 11 years ago
    Mike,  I saw your excellent  presentation for the Pi challenge.  I'm going to set up a ds18b20 with my pi.  Would like to see how gspread and cron fits in.  Thanks !
  • d6diesel
