CodeBug
  • CodeBug
CodeBug
Forum Christmas Presents from Codebugs
Join CodeBug to participate - click to join for free!
  • Subscribers 12 subscribers
  • Views 1957 views
I made a rocket for my nephew for christmas, a colour star provides the engines and a codebug does the countdown sequence.
A 2L drinks bottle provided the fusilage and a cardboard box supplied the fins.
I had to sacrifice a better battery than intended as the cheap one kept turning itself off during the countdown (power save feature).
My brother-in-law was slightly disappointed witn the feedback, apparently the lego millennium falcon was quite expensive so becoming second best present was a little blow.
Here's the code.
Here's the video (you Tube)
I made four christmas trees with a codebug colour star on top of each (two daughters, two nieces).
The trees were made out of hardboard and covered with green paper, the colour stars were wrapped in tinsel (as a diffuser, they are two bright otherwise). A USB battery pack was used as the power supply.
Here is the code.
short (4 Seconds) video of it in operation
    e14 Contributor over 10 years ago in reply to mcb1 +1
    As Clem noted, the links were broken because I copied and pasted them from the codebug forum, so the Hyperlink code format was wrong (different between that bulletin board and here) they should all work…
    mcb1 over 10 years ago
    It seems the links don't work.
    Also can you add some images to the post (rather than a link to somewhere else that could be removed).
    I'm sure there are others will will want to emulate these.
  • clem57
    clem57 over 10 years ago in reply to mcb1
    CodeBug – Colour star
    mcb1
    Looks like an abutment problem...image
  • clem57
    https://www.youtube.com/watch?v=mEeaTFc4D0I&feature=youtu.be
    video too
    mcb1 over 10 years ago in reply to clem57
    Cheers
    Great Rocket ... image
    abutment problem
    Not sure I'm familiar with the term ...
    As Clem noted, the links were broken because I copied and pasted them from the codebug forum, so the Hyperlink code format was wrong (different between that bulletin board and here) they should all work now that I've edited them correctly.
    I forgot my Phone this morning so I don't have access to the photos I took.
