CodeBug
  • CodeBug
CodeBug
Forum CodeBug Driving a Servo
Join CodeBug to participate - click to join for free!
  • Replies 8 replies
  • Subscribers 12 subscribers
  • Views 2430 views
  • pwm_controller
  • code_bug
  • codebug
  • servo
  • servo_driver
  • servo_control
spannerspencer
spannerspencer over 11 years ago
I picked up a codebug the other day, when I met the guys who created it, and had a quick lash with it this evening. I've got a personal project in mind that involves driving at least one servo (probably two), and I was curious as to whether the CodeBug could be the brains behind it.
A little bit of jitter, but turns out it works pretty damn well! More than adequate for my project's needs (more on that as it takes shape. Hint: pop culture fans will love it!). Sorted!
    Jan Cumps over 11 years ago +1
    For the win! That's not jitter. That's smooth.
    balearicdynamics over 11 years ago in reply to spannerspencer +1
    Should make a try in some way. But I have just an idea. Thank you for the code Spanner. Enrico
    For the win!
  • spannerspencer
    spannerspencer over 11 years ago in reply to Jan Cumps
    It's not too bad, yeah image
    It's even better now, as I've adjusted how it works. Rather than button A moving it in one direction and button B moving it back, I've set specific positions (this is what the project will need). So now, when you press button A it immediately (and smoothly) moves to the first position. Press button A again, and it switches to the other position.
    One small issue is that if you hold button A down, it continually rotates between the two positions, which is something I'd like to eliminate. Still though, the CodeBug's doing me proud! image
    How did you managed the PWM servo control ? I am curious...
  • spannerspencer
    spannerspencer over 11 years ago in reply to balearicdynamics
    It all went with surprising ease. I've just published the code I used over on the CodeBug site, if you'd like to take a look at it: http://www.codebug.co.uk/explore/codebug/805/
    By the way -- if you can see a way to stop the servo running back and forth between the two positions if you hold down button A, that'd be much appreciated! I'd prefer that you have to release button A and press it again in order for the servo to move back.
    Enrico
  • kiphansen
    kiphansen over 11 years ago in reply to spannerspencer
    Spencer --  Instead of a Pause at the end, add in a check for "not - Button A - pressed" --  loop that to prevent the code from continuing until Button A is found NOT PRESSED (ie: released) before looping back to the "if Button A pressed" line.
  • spannerspencer
    spannerspencer over 11 years ago in reply to kiphansen
    Ah, interesting idea -- I'll add that in. Funnily enough, this project will be using a foot switch, and I ordered a latching one by mistake. But it could actually work very nicely using this method. Nice one kiphansen!
    Here is PiGraham's code for driving a servo, he had a slightly different approach.
    CodeBug – ServoBug
