CodeBug
  • CodeBug
CodeBug
Forum USB port came off.
Join CodeBug to participate - click to join for free!
  • Subscribers 12 subscribers
  • Views 2145 views
  • codebug
USB port came off.
grahamchow
grahamchow over 11 years ago
My daughter, who is 9, accidentally broke off the usb port off the codebug (who could not see that coming?).
I manage to solder it back on some how (I don't have any smd tools, so that was a small miracle). I'm actually going to get some paste.
I think they should have used a through hole mount for the USB connector or a better mounting strategy. I see the Raspberry PI does look better. I really think that if they are aiming for 7-10 yo, this would be essential even if it added a dollar or two to the cost.
Graham Chow
    balearicdynamics over 11 years ago in reply to mcb1 +1
    Excluding the option to keep it in the pocket, as I have done with the problem that sometimes you can press a button and the bug start flashing, I see that has done / is doing some experients. I have an…
  • gadget.iom
    gadget.iom over 11 years ago in reply to mcb1 +1
    The CodeBug website has a little guide on the topic of wearables. http://www.codebug.org.uk/learn/activity/59/wearables-guide/
    mcb1 over 11 years ago
    I seem to recall that was asked for on the initial Rpi, and didn't arrive until much later.
    Maybe a short cable that is fixed to the codebug might help prevent any future strain on this particular one.
    Mark,
    the problem of the short cable instead a more reliable soldering make the difference about the wearability of the device. Me too I noted that the USB is one of the weak points of this device ..
    Enrico
    mcb1 over 11 years ago in reply to balearicdynamics
    Yes but I was meaning only while experimenting with this particular 'injured' device.
    Has anyone found a really good method to wear it.??
    Excluding the option to keep it in the pocket, as I have done with the problem that sometimes you can press a button and the bug start flashing, I see that has done / is doing some experients. I have an idea but I should verify it. Not yet sure.
  • gadget.iom
