STEM Academy
STEM Academy
Forum Wind turbine design
  • Replies 18 replies
  • Subscribers 59 subscribers
  • Views 4258 views
  • stem space
Wind turbine design
OK not sure whether this should be here or in power management, but I am choosing engineering
This is a new subject to me in relation to the physical build of a turbine
I wonder if anyone can tell me why the vanes are perpendicular to the wind direction instead of parallel to the flow of wind
In my eyes it may be easier to build a turbine with variable direction blades depending on the speed of the wind so that they are facing the sky, which would reduce the directional workings from the complexity of the design
  • dragonstyne
    dragonstyne over 11 years ago in reply to mcb1 +1
    I agree, over reving is a big issue also, more surface area provides better performance in lower wind situations. Larger wind turbines tend to create RF noise due the varying capacitance between the blades…
    e14 Contributor over 11 years ago in reply to dragonstyne +1
    Are now we are getting into different area of problems that I had forgotten about EMF and RF interference, I remember testing equipment against that (in an old employment) but had not even thought about…
    mcb1 over 11 years ago in reply to e14 Contributor
    I would have thought by having 3 blades would have resulted in less vibration on the blade bearings
    I think it has to do with frequency and their ability to eliminate/reduce it.
    They also have a "more efficient transmission" although not sure if it is or isn't in real life.
    I believe their trial unit showed some higher than expected audiable noise and a failure due to very high winds ...but that's what trials are for.
  • dragonstyne
    Larger wind turbines tend to create RF noise due the varying capacitance between the blades and the mast as the prop spins.
    I've seen turbines with pitchable props an one other with a twistable prop to bite more or less air.
    -Steve
    Are now we are getting into different area of problems that I had forgotten about EMF and RF interference, I remember testing equipment against that (in an old employment) but had not even thought about the mechanical generation from the turbines and their natural potentials from ground voltage
    - Mike
  • dragonstyne
    There are turbines with vertical blades, serpentine blades and so forth.  These are usually smaller because of the  complexity of the carrier assembly as the size increases.
    However, thinking outside the box is the catalyst of innovation.
    -Steve
    From the start of the discussion has certainly given me some food for thought, with some ideas coming through
    mcb1 over 11 years ago in reply to dragonstyne
    Wasn't aware of the RF thing ...
    cheers
  • Problemchild
    Problemchild over 11 years ago in reply to dragonstyne
    Yeah the RF issue is interesting. I bet they also cause all sorts of propagation or reception problems  if you are to some extent bouncing signals off the blades
  • dragonstyne
    dragonstyne over 11 years ago in reply to Problemchild
    You get all sorts of interesting effects when transmitting through a
    wind farm.
    -Steve
