STEM Academy
STEM Academy
Forum Python Question - Formatting
  • Subscribers 53 subscribers
  • Views 1357 views
  • python
  • raspberypi
  • stem space
mikedavis
mikedavis over 11 years ago
I am working on a time lapse project, and I would like to be able to save my files with a time stamp (something like YYYYMMDD-HMS.jpg).  So I used the code below:
import time
import picamera
VIDEO_DAYS = 1
FRAMES_PER_HOUR = 360
FRAMES = FRAMES_PER_HOUR * 3 * VIDEO_DAYS
file = time.strftime("%Y%m%d-%H%M%S")
def capture_frame(frame):
    with picamera.PiCamera() as cam:
        time.sleep(2)
        cam.led = False #Turn off the Red LED
        cam.capture('/home/pi/camera/'+file+'.jpg' % (frame))
# Capture the images
for frame in range(FRAMES):
    # Note the time before the capture
    start = time.time()
    # Wait for the next capture. Note that we take into
    # account the length of time it took to capture the
    # image when calculating the delay
    time.sleep(
        int(60 * 60 / FRAMES_PER_HOUR) - (time.time() - start)
I end up getting this error message.
File "camera.py", line 20, in <module>
  File "camera.py", line 14, in capture_frame
TypeError: not all arguments converted during string formatting
I feel like I am missing something simple or obvious, but I am not sure what that is, and my inexperience is starting to show.
Any help would be greatly appreciated, thank you!
    balearicdynamics over 11 years ago in reply to mikedavis +1 verified
    You shown me just what I was trying to explain ! cam . capture ( '/home/pi/Desktop/frame%03d.jpg' % frame ) you see that the % frame is a variable that can't fit space (in your code) in the compound string…
    0 balearicdynamics over 11 years ago
    I am not a python expert, but the following line sounds strange:
    first of all because there are no spaces between '+' and because I suppose that the last % (frame) refers to a value that is not chained to the string. Or I am wrong ?
  • mikedavis
    0 mikedavis over 11 years ago in reply to balearicdynamics
    I think that it is not chained to the string.  I believe that it basically counts the number of pictures that are taken in that portion of the code.  The original code I used (and always works) is from the RaspberryPi.org site.
    import time
    import picamera
    VIDEO_DAYS = 5
    FRAMES_PER_HOUR = 1
    FRAMES = FRAMES_PER_HOUR * 24 * VIDEO_DAYS
      time.sleep(2)
      cam.capture('/home/pi/Desktop/frame%03d.jpg' % frame)
      start = time.time()
      time.sleep(
    0 balearicdynamics over 11 years ago in reply to mikedavis
    you see that the % frame is a variable that can't fit space (in your code) in the compound string. In the origina the /frame%03d.jpg Means:
    Format three integer digits left-aligned with zeroes in this point, then at the end of the string you have the variable that is used creating the file name.
    I suggest that you create before a string '/home/pi/camera/' + file + '%03d.jpg' so you don't stress the program to recreate for a lot of times always the same string that is the formatter
    Then place the string in your command with the %frame that is the replacement variable for the formatter.
  • mikedavis
    THANKS!  That did it!  I also showed me that the file names are going to be named with the time just once, as opposed to every time.  That is good enough for me!
    Thank you!
