microbit
  • microbit
microbit
microbit Forum BBC MicroBit Announcement Now Live
  • Replies 32 replies
  • Subscribers 55 subscribers
  • Views 6686 views
  • bbc_microbit
  • micromemories
  • bbc_micro
spannerspencer
spannerspencer over 11 years ago
From classrooms to wearable tech - the beeb is back!
Not sure if you guys have heard about this one yet, but the BBC MicroBit seems like it'd be right up the Top Members' techno alley.
The Beeb has announced the program now, which means we've run out some content around the initiative as well. Thought you guys would like to check it all out:
hexwab has kicked things off with a great retrospective on the BBC Micro of 30 years hence, and I've put down my own broken memories of high school computer rooms to usher in our micromemories tag.
If any of you guys spent your school days tapping away at the Beeb's colourful keyboard, blog it up in the The specified item was not found. (or comment on the existing coverage) to tell the community about those hallowed days of yore! And don't forget to add in the micromemories tag to put yourself in the running to win a C64 plug 'n' play game thing.
Let's go, retro!
  • Workshopshed
    Workshopshed over 11 years ago in reply to spannerspencer +7
    Here's one I made earlier (a lot earlier). Powered by a ZxSpectrum, not a BBC.
  • spannerspencer
    spannerspencer over 11 years ago in reply to Robert Peter Oakes +4
    You're not wrong there, Robert Peter Oakes . It's not just the kids learning to code -- it's the teachers that'll need backup, support and ideas on what to do with it. Although there are already some cool…
    e14 Contributor over 11 years ago +3
    Damn you BBC Micro!! Its amazing how many our school had that went unused.. I made it my mission to put scrolling text on them all that I learnt from programming my Acorn Electron! check out the "micro…
    shabaz over 11 years ago in reply to Workshopshed
    Problemchild this is a more advanced CAD system than yours - Andy's features straight lines!
  • Workshopshed
    Workshopshed over 11 years ago in reply to shabaz
    Not bad for a 14 year old. I do remember some kind of weird timing issue with the interface which was cunningly worked around with some machine code.
    Here's the output from one of the test programmes, I have a feeling it was driven using cursor keys. A problem machining the screw threads meant that all of the straight lines had a sinusoidal component.
  • Problemchild
    Problemchild over 11 years ago in reply to shabaz
    Mine does with the Ruler expansion pack....Otherwise you need to stick with the arbitrary Spline Auto Renderer option (TM)
  • Problemchild
    Problemchild over 11 years ago in reply to Workshopshed
    ZX Spectrum For The Win :-)
  • Workshopshed
    Workshopshed over 11 years ago in reply to Problemchild
    Here's a new ruler you'll soon be able to buy, although I'm not quite sure of the scale used, perhaps that's the new decimalised inch we've been hearing about.
  • Workshopshed
    Watched the video at :
    More Details On The New BBC Micro Bit Computer (Video)
    rather than needing phones it would be much more fun if the kids could send messages to each other using the blue tooth for communication between two devices and the two buttons to enter the data in as binary.
  • johnbeetem
    johnbeetem over 11 years ago in reply to Workshopshed
    Andy Clark (Workshopshed) wrote:
    Rather than needing phones it would be much more fun if the kids could send messages to each other using the blue tooth for communication between two devices and the two buttons to enter the data in as binary.image
    With two buttons you can send Morse Code using the same trick as an Iambic Paddle: https://en.wikipedia.org/wiki/Telegraph_key#Iambic_.28dual-lever.29_Paddles
    Pressing one button gives you a series of dits, pressing the other gives you a series of dahs, and pressing both alternates dits and dahs.  You can send data really fast using this technique, and don't have to injure your neck staring at a tiny keyboard.  The buttons have to be really responsive, though.
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to Workshopshed
    3 IO pins, 0, 1 and 2 then 3V and gnd for use with crock clips, also 4mm banana plug compatablw holes so the minions will be covered, loads more io if you use the 0.1" pitch fingers into what has to be a propriatry connector wich sucks, not directly breadboard compatable
    5X5 LEDs, 2 user IO buttons, BLE, USB and an ARM cpu so not bad capability overall
    given to all year 7 kids this fall
    what about the rest of us though, no mention of being available for sale or for other purposes like us to help with coding and getting the kids started (The teachers will be strugling on their own to teach kids this stuff)
  • Workshopshed
    Workshopshed over 11 years ago in reply to Robert Peter Oakes
    I'd pay £10 for one to play with.
    for sure, me too
