microbit
  • microbit
microbit
microbit Forum Bluetooth basic problem with the micro:bit
  • Replies 15 replies
  • Answers 4 answers
  • Subscribers 54 subscribers
  • Views 10780 views
  • bluetooth
  • ble
  • bbc micro:bit
  • bbc microbit
neilk
neilk over 9 years ago
I've recently received my micro:bit and worked through most of the projects in jlucas 's blog - great start.
I'm keen to code on my Android tablet and smartphone and then use bluetooth to flash the .hex file to the micro:bit, but I'm not having any success.
I've downloaded the SAMSUNG app to both my phone and my tablet and after a lot of fiddling around, I can pair both devices to the micro:bit. I'm sure youngsters will get very very frustrated with this process!! I failed so many times to even start the pairing process that I found and downloaded a ble checker to both my phone and tablet - yes they both support ble - but not all phones/tablets do & that could be a problem for some users.
However, before I can flash the .hex file across, I have to connect to the micro:bit. Both the phone and the tablet repeatedly refuse to connect to the micro:bit, so I am stymied.
  • tony1tf
    tony1tf over 9 years ago in reply to neilk +2
    Very clever - Neil. This worked for me - I was getting the "GATT ERROR" but following your workaround in exactly the given order enable me to upload some previous compiled code for driving a model car…
  • henrikbirkholm
    henrikbirkholm over 9 years ago +1
    Hi. We would love to hear about your work around. How you get it to sync everytime. After we transfered our first Python, the bluetooth sync functionality is gone. The pairing functionality was also gone…
  • neilk
    neilk over 9 years ago in reply to henrikbirkholm +1 verified
    Hi henrikbirkholm Hello Henrik Unforunately, installing a MicroPython script ALWAYS destroys the bluetooth pairing ability and the "workround" (courtesy of Joe Finney, Lancaster University) will NOT work…
  • anbreen
    0 anbreen over 8 years ago in reply to henrikbirkholm
    I also need to workaround. My micro:bit is paired to my phone, but none of the Blue Tooth apps can find my micro:bit. Thanks!
  • lp12
    0 lp12 over 8 years ago
    In your original post you said you could pair both of your devices to the microbit,
    but are you pairing them separately or at the same time?
    Thank you in advance.
  • neilk
    0 neilk over 8 years ago in reply to lp12
    Hi lp12
    To be perfectly honest, I can't remember, and it's been quite a while since I've worked with the micro:bit. However, I've just tried and I can pair to my android phone and to my android tablet at the same time.
    Well what I mean is that I can pair the micro:bit to my phone and then go on and pair it to my tablet.
    I don't know if this helps.
    Neil
  • jharris1993
    0 jharris1993 over 7 years ago in reply to neilk
    Neil,
    Geez!  Someone at embed - the people who wrote the firmware - must have a PhD from the Microsoft School of Obscurity - that has to be the absolute ugliest work-around I have ever seen!  I cannot imagine a less obvious way to do something. . . .
    I will have to try this myself though I give total respect and props to you for posting your detailed instructions - other postings allude to this but don't go into the detail you did.
    Suggestion:
    Would you please change the "correct answer" designation to point at the posting where you provided Henrik with the detailed list of instructions?  This should be what people look for when searching this article.
    Thanks!
    Jim "JR"
  • neilk
    0 neilk over 7 years ago in reply to jharris1993
    Hi Jim
    Good Idea!
    Done
    Neil
