STEM Projects
  • STEM Projects
STEM Projects
Blog Book Carrying Robot #5 How to setup MATLAB and Simulink to run a standalone Image Processing script on Raspberry PI using Raspberry PI Camera
Join STEM Projects to participate - click to join for free!
  • Author Author: mohanedessam
  • Date Created: 5 Sep 2015 4:30 AM Date Created
  • Views 1807 views
  • Comments 9 comments
  • image_processing
  • teachers_pet_robotics_design_challenge
  • teachers_pet
  • matlab_raspberry_pi
  • raspberry-pi
  • matlab
  • teachers pet robotics design challenge
  • digital_imaging
  • book_carrying_robot
  • simulink
mohanedessam
mohanedessam
5 Sep 2015
I showed in my previous post that I was able to run a standalone user defined MATLAB script on Raspberry PI, that can take images from Raspberry PI Camera and control two motors using GPIO pins.
In this Post I will explain how to this, so please refer to my video:
First, if your "mex -setup" command is giving an error, please try to install Microsoft SDK from this link:
http://www.mathworks.com/matlabcentral/answers/101105-how-do-i-install-microsoft-windows-sdk-7-1
However, I had some problems installing that, but it worked after I followed the instructions in this video:
To configure the Raspberry Pi camera to run on V4L2 video capture block, please refer to this link:
Use Camera Board with V4L2 Video Capture Block - MATLAB & Simulink
I have attached the Simulink model I developed in the video, and also a separate m-file that contains the function script in case you can't view the function in simulink.
After this post I have made some updates to my model and code please check this post for the updated version.
processing_separate_function.m.zip
show_progress.rar
    DAB over 11 years ago +1
    Could you boost the audio a little? I can just barely hear your voice on the video. Thanks DAB
    السلام عليكم بش مهندس مهند ممكن تواصل معاك عن طريق الايميل او الفيس بوك .. انا اعمل على مشروع UGV ROBOT وكنت محتاج مساعدة في جزء معين من الماتلاب واللراسبيري باي
