STEM Projects
  • STEM Projects
STEM Projects
Blog Final Post... Failure
Join STEM Projects to participate - click to join for free!
  • Author Author: adnathanail
  • Date Created: 13 Sep 2015 10:13 PM Date Created
  • Views 739 views
  • teachers_pet
  • r4gv
  • teachers pet robotics design challenge
  • r4gv_project
adnathanail
adnathanail
13 Sep 2015
*Edit* Here's a picture of the final code and attatched is the file.
So to reiterate what I said in the video. I think it's either the human error in my measuring of the robots movement in order to calibrate it, the cable nudging the robot out of the way, or most likely the issue from a couple of blogs ago which I am not 100% sure I fixed. Either way it doesn't work.
Finally I would like to repeat my thanks to Element14 and Mathworks and a big thank you to Adafruit too who I forgot to thank in the video.
I have greatly enjoyed the process and I feel I have learned a lot.
Signing off for the last time
Alexander Nathanail
grid_test.m.zip
    DAB over 11 years ago +1
    Nice post. It often more of a learning experience when you fail to fully succeed verses getting everything to work first time out. So for me and others, your attempt provides us with a lot of information…
    shabaz over 11 years ago
    I wouldn't call it an entire failure. Your goal was very ambitious but you met most of the objectives with the equipment you had, it is (as you've noticed) extremely difficult to implement such behavior, i.e. translating your cartesian output into robot traversal through speed and time instructions for the two wheels and coping with friction, acceleration, servo errors at different speeds and so on. It is very hard with those types of servo motors, but also the algorithm is difficult to implement too. In the past, there were commercial plotting robots that could do this, but they used stepper motors and so had a far, far easier job than the servo method.
    I think the fact that you interworked the platform with Matlab and got output is pretty impressive anyway. None of this was trivial.
    Nice post.
    So for me and others, your attempt provides us with a lot of information we can use on our own future products.
