STEM Projects
  • STEM Projects
STEM Projects
Blog Shedule & Homework Robot - Sound System's Hardware (part #2)
Join STEM Projects to participate - click to join for free!
  • Author Author: yuritikhonov
  • Date Created: 14 May 2015 7:59 AM Date Created
  • Views 1317 views
  • Comments 7 comments
  • schedule_bot
  • teachers_pet
  • robot
  • matlab
  • teachers pet robotics design challenge
yuritikhonov
yuritikhonov
14 May 2015
Good day comrade!
Today we'll talk about the audio hardware of my robot. Generally speaking, my sound system will consist of two parts:
  • melody generator;
  • speech generator.
The latter will be discussed in a future article, but today (and next week), our attention will be focused on the melody generator. So here's what I came up with:
The circuit operates as follows:
  • digital code of note comes from the MCU to the DAC;
  • DAC converts the note into an analog signal U = 0..5V;
  • analog signal U is fed to VCO, which converts it into frequency f = 0.5..10kHz;
  • frequency signal f from VCO is supplied with the power amplifier;
  • signal from the power amplifier enters the loudspeaker from which the sound is coming.
Pretty simple!
Circuitry of our "sound card" is very simple and clear:
Let's look at the purpose of each part:
  • IC2 - microcontroller generating digital codes;
  • R1-R10 and IC3A - improvised DAC;
  • IC1, R10-R13 and C1 - a simple VCO, built on classic 555 timer;
  • R14-R15 - frequency control (for fine tuning);
  • IC3B - power amplifier (U = const, I - enhanced);
  • SG1 - piezo speaker.
I’d like to explain one thing: DAC in this scheme is performed on the base  of  voltage divider, but you may have noticed that the scheme additionally uses Op-Amp IC3A. Why is it needed? Everything is very simple! In this case IC3A is used as a buffer stage to avoid the influence of signals from outside on the DAC.
Well, we’ve got the scheme, it's time to put it into practice! To begin with, I had to walk to the store and buy all the necessary electronic components:
Then came the hour of manufacturing PCB. The board is very simple, and I decided to draw it in not less simple program Sprint Layout:
Finally, I made the PCB. Traditionally, for this purpose, I used an iron and a laser printer:
And now it's time to test! The scheme worked at once, but an important drawback of piezo speaker was detected: these speakers have their own oscillation frequency (in my case 3.3kHz) and in case of applying to the speaker of a less frequency (e.g. 490Hz), the frequencies are summed:
In general, this does not prevent the system to work, but if I get a chance, I will get a normal speaker capable of reproducing clear sound.
Finally, I offer you a short video showing the work of my "sound card":
Next week, we will create music for our "sound card" using Matlab. See you soon!
  • dragonstyne
    dragonstyne over 11 years ago +1
    Nice job so far Yuri. [][][]Steve
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +1
    have you looked at using an R-2R ladder for the resistor network, it would simplify the DAC by only requiring 2 resistor values and is a common technique for making DACS See the WIKI page for more details…
    DAB over 11 years ago +1
    Are you going to use a real time clock chip to keep track of days and hours or just run off of the board clock? DAB
  • yuritikhonov
    yuritikhonov over 11 years ago in reply to anujaapte
    Thanks for advice! I'll try it.
  • anujaapte
    anujaapte over 11 years ago
    Here's a tutorial that may be relevant - Create your own music with Simulink and Arduino
  • yuritikhonov
    yuritikhonov over 11 years ago in reply to DAB
    Hi DAB! I'm glad to see you again!
    I'm use 555 timer (it is not a real time clock) to generate sound.
    But your Idea is a really good! I have some real time clock IC's in my collection and if I find some extra time - I'll use it in my project!
  • yuritikhonov
    yuritikhonov over 11 years ago in reply to Robert Peter Oakes
    Yep, I know about R-2R DAC but in my case for this circuit I need a little more components (resistors). But yes! My circuit is more complex in adjustments.
