Publications
Publications
Blog A Baby Monitor as a Lab Tool
  • Author Author: gervasi
  • Date Created: 26 Oct 2011 4:14 PM Date Created
  • Views 549 views
  • cgervasi:dit
  • rf
gervasi
gervasi
26 Oct 2011
Last week while I was debugging a memory bus, my wife came down and asked if I could watch the kids when they woke up.  I knew the design was good, so the bus problem was just an assembly defect, which I hoped to find before the baby woke up.  She handed me the old 49MHz FM baby monitor receiver.  I set it next to the scope and began looking at each line of the bus.  When I touched the probe to a digial net, the high-frequency components coupled from probe’s ground lead and/or from the inside the scope itself causing the baby monitor made noises like the baby monitor in the movie Signs detecting the aliens.  image
As I went down the lines of the bus, I realized I could tell from the sound whether there was activity on the bus.  A low-duty-cycle pulse train made a different sound from a line with a 50% duty cycle square wave.  I suspect pulses with faster edge rates would sound louder due to their higher frequency spectral components.  I found I could tell an awful lot about the waveform without looking up at the scope.  Eventually I found a memory pin that didn’t have much activity on it.  The pad beneath it, however, had a good deal of bus activity.  It turns out there was a cold joint that I could close by pushing on the IC.  I put the probe on the IC pin, pushed down on the IC, and listened to when the noise on the baby monitor changed.  I reflowed the joint, and the problem was fixed.  I’m not sure if I would have noticed if the baby had cried in the middle of all this, but she did not wake up until after the board was fixed.  I probably could not have found the cold joint as fast without the audible indications from the baby monitor.
It seems like an audible indication feature on a scope designed to convey some signal information could be at least as helpful as noise that finds its way through a cheap baby monitor’s signal chain. The ability to get some information without looking up is a bigger time saver than I would have imagined.
    DAB over 14 years ago
    Great story.
    I picked up an old baby monitor at a garage sale.  When I get some time, I plan to see if it can be used to monitor the front and back doors of my house.  It is amazing what you can find when you go out and just look around.  I have picked up a number of very useful items in this way.
    With your post I now have even more ideas on how to repurpose some of the older electronics.
    I always said it is better to be lucky than good, but even if you are good, sometimes you just need a little break to get even better.
