Publications
Publications
Blog A "Spider-bot," creeps into the market for experimenters
  • Author Author: Eavesdropper
  • Date Created: 12 Apr 2011 1:02 AM Date Created
  • Views 531 views
  • Experiment
  • engineer
  • eavesdropper:dit
  • robotics
  • robot
  • diy
  • hacker
Eavesdropper
Eavesdropper
12 Apr 2011
Similar with the TurtleBot, Kondo Robot seeks to give an affordable home experimenting robot to the masses. Their offering, an intimidating spider like robot with 6 legs called the KMR-M6. To reduce costs, a clever leg appendage uses 2 servos and a mechanical spring actuator. Legs can be purchased separately so the ambitious can build their own multi-leg creation. Attach a Microsoft Kinect to this "hexapod" robot, and Turtlebot may have to roll aside. The KMR-M6 can navigate over complex and rough terrain. The low center of gravity will also keep it from tipping. At the center of the KMR-M6 bot is a Kondo RCB-4HV controller powered by a 10.8V 800mAh Ni-MH battery from ROBO. Available in May for $880 USD. Although Kondo Robot is based in Japan, a fairly extensive community is available for aid, support, and design examples.
Eavesdropper
