Publications
Publications
Blog Bolt in the head reads neural signals
  • Author Author: Eavesdropper
  • Date Created: 17 Jun 2011 8:34 PM Date Created
  • Views 752 views
  • research
  • test
  • dit
  • eavesdropper:dit
  • medtronic
  • on_campus
  • measurement
  • university
  • medical
  • technology_for_the_disabled
  • sensor
Eavesdropper
Eavesdropper
17 Jun 2011
BioBolt showing microcircuit film sensor
To have a brain implant that works your brain must be exposed with current technology. Unless you are into hats, then this is not a practical option. University of Michigan has a solution that stays outside the bone. Reading neural signals from the brain as best sensed with direct contact, second best being exo-skull, and least accurate is completely external. Toys may work ok external to the skin, but the skin is a fairly good insulator and prevents solid reading without proper contacts. Professor Euisik Yoon, leading the team on the case, takes the device, dubbed the BioBolt, and screws directly into the skull making contact with the brain. The Biobolt is then covered with skin to prevent the infection. Yes, the Biobolt is in the shape of a hex bolt, which must aid in its implantation.
The BioBolt's sensors are placed on the bottom that are in contact with the brain. The overall pattern of neurons are sensed. The signals are amplified, filtered, and translated to data and sent through the patients skin to a computer. Using the skin as a signal pathway, the BioBolt's power demand is kept quite low.
The next step for Yoon and his team is to send the BioBolt's data through the skin to another device to collect and store the data for long periods of time. Yoon mentions the use of a watch or pair of earrings for this purpose. Another step is to use the same signals through the skin to stimulate a paralyzed limb or body part, as a sort of bypass to a failed nervous system.
I would like the shape changed before I implant such a device. Sharp bolt patterned edges sound uncomfortable.
Eavesdropper
  • Eavesdropper
    Eavesdropper over 15 years ago in reply to DAB
    The neural sensing net on this bolt is not all encompassing. Read the embedded link in this post to more on covering the whole brain.
    Perhaps the "bolt" could connect to a larger sensor then.
    But please, make the bolt shallow and smooth U of M.
    E
    DAB over 15 years ago
    Given the metal I already have placed in my body, a bolt in the head is probably further than I am willing to go for science. image
    It looks like this approach may actually make the pluggable human computer interface a reality in the near future.  There are a lot of science fiction stories that speculated on the advantages of having the brain directly connected to the computer.  Not that I would want to do the alpha or beta testing, but the experience could litterally be Mind Blowing.
    Thanks
