Publications
Publications
Blog Human heart based generators
  • Author Author: Eavesdropper
  • Date Created: 17 May 2011 7:56 PM Date Created
  • Views 563 views
  • alternative_energy
  • dit
  • eavesdropper:dit
  • medtronic
  • on_campus
  • generator
  • university
  • medical
  • energy
Eavesdropper
Eavesdropper
17 May 2011
Two micro-generators are on their way to powering pacemakers and other implanted medical devices. The two operate in drastically different ways. The first from Alois Pfenniger of the University of Bern and Bern University of Applied Sciences in Switzerland have developed a turbine that is placed in one of the heart's arteries. Pfenniger explains the concept, "The heart produces around 1 or 1.5 watts of hydraulic power, and we want to take maybe one milliwatt. A pacemaker only needs around 10 microwatts." In a test, Pfenniger used a millimeter-wide tube that would mimic the internal thoracic artery. Using 3 different turbine, that he did not make, he was able to get 800 microwatts from the most efficient. Which is 80 times the power needed to power a pacemaker. The main issue comes from turbulance caused by the turbines, and the possibility of blood clotting.
The other micro-generator comes from Paul Roberts of Southampton University Hospitals NHS Trust. His design works by using the blood pressure changes, externally,  of a beating heart to move a magnet back and forth for a miniature Faraday generator. Roberts placed this device inside of a test pig and was able to get 2 microwatts from the device on average. This is far less than what is needed for the average pacemaker.  Roberts talks of his next steps, "the drive for all of this is to potentially reduce sizes of devices, and equally to accommodate increasing demands placed on devices, such as more diagnostics and wireless communications." To do all this, Roberts is seeking partners and government funding.
What about magnetic resonance charging of a pacemaker battery instead?
Eavesdropper
Pic via Alios Pfenniger, one of the turbine rotors
  • Eavesdropper
    Eavesdropper over 14 years ago in reply to DAB
    Paul Robert's device works in that fashion. Though the output is low, at least it doesn't create turbulence in the heart. I have also read about heat harvesters, and another that uses blood sugars. But I would personally prefer a external charging solution.
    E
    DAB over 14 years ago
    Actually, when I read the article, I was picturing a Piezo powered structure wrapped around the aorta.  Each heart beat could then generate its own power for the pacemaker without wasting any of the heart flow energy.  Though it might still need an energy storage device just for safety and as a backup.
    Very interesting.
