      • Japan
      • Vietnam
Publications
Publications
Blog Long-term memory switch
  • Author Author: Eavesdropper
  • Date Created: 21 Jun 2011 8:11 PM Date Created
  • Views 703 views
  • Comments 5 comments
  • test
  • dit
  • eavesdropper:dit
  • on_campus
  • measurement
  • university
  • medical
Eavesdropper
Eavesdropper
21 Jun 2011
Rat experiment diagram & Theodore Berger (via USC)
Alzheimer's disease may one day be defeated with a simple "on" switch.
In an experiment, Theodore Berger of USC Viterbi School of Engineering, and his team, was able to make rats remember and forget with a toggle of a switch. Working along with a team lead by Sam A. Deadwyler of the Wake Forest Department of Psychology and Pharmacology, neural transmissions within the rat's hippocampus were the target of the several different augmentations.
During the study, rats were taught a particular task, push a lever left then right for water. Changes in the rat's hippocampus were recorded. This area is responsible for long-term memory. The team them blocked the neural firings within the sub-regions CA3 and CA1 of the hippocampus using pharmaceutical drugs. The trained rats no longer knew what to do.
Berger and his prosthetics research team created an artificial hippocampal system that can duplicate the pattern of signals between the CA3 and CA1 system. In other words, creating an artificial triggering of the long term memory area for the rat to access. When the team activated the embedded electrical device, sent the artificial hippocampal signal, the rat's long-term memories were  restored.
Additionally, when the electrodes were implanted in unobstructed hippocampus rats, their memory functions strengthened and improved overall. Burger writes, "These integrated experimental modeling studies show for the first time that with sufficient information about the neural coding of memories, a neural prosthesis capable of real-time identification and manipulation of the encoding process can restore and even enhance cognitive mnemonic processes."
The collective teams plan on applying this technology on primates. They hope to one day restore function to those who suffer from stroke, accident, and of course Alzheimer's disease.
Eavesdropper
  • Eavesdropper
    Eavesdropper over 14 years ago in reply to Former Member
    The concept of bypassing failing brain functions is a great step. I hope to see more of it, and soon. At least, until a way is found to fix the failing components of the brain.
    E
  • Former Member
    Former Member over 14 years ago in reply to DAB
    I can absolutely identify ,
    DAB over 14 years ago
    Hi Addidis,
    I can sympathise, my accident left me in constant pain and long term concentration is no longer possible.  Plus my ability to deal with people one on one has been severely compromised.
    I try to explain to people that you spend all of your life building filters in your brain to stop you from reacting to comments before you have time to find the right response.  When you are in constant pain, the brain refills those filters with pain messages so that you are no longer inhibited from responding before you think! image
    Unfortunately, that was enough to convince me to retire as my work required a great deal of interaction with others and the pain made that impossible to do.
    So cheer up, you are not alone.  People who have not gone through the process have no idea how frustrating it can be to be trapped inside a nonfunctioning verbal interface when you have a need to communicate.
    Good luck,
  • Former Member
    I really hope this pans out too. I got into a car wreck and have some rather extreame memory issues as a result. The best way I have found to explain it is a PIC with the WDT on when you cant stop it from resetting.  Its so weird to see this article because memory really is that easy to flip on and off, for me its not under my control but i do believe this has potential from living with what i do.
    I sincerely hope that he succeeds.
