Publications
Publications
Blog Magnetic Tongue, the machine taste tester
  • Author Author: Eavesdropper
  • Date Created: 31 Oct 2011 8:14 PM Date Created
  • Views 730 views
  • research
  • test
  • nuclear
  • magnetic
  • spectroscopy
  • eavesdropper:dit
  • industry
  • hmi
  • medtronic
  • on_campus
  • resonance
  • university
  • medical
  • sensor
  • communication
Eavesdropper
Eavesdropper
31 Oct 2011
Chemical shift test using Nuclear Magnetic Resonance Spectroscopy (NMR)
on a hexaborane B6H10 molecule. (via wiki)
When it comes to taste testing there are now two options, a refined palette and Nuclear Magnetic Resonance Spectroscopy (NMR). In fact, the latter option might replace human testing all together. According to the paper published by researchers in Milan (J Agric Food Chem) the NMR method correlates spot on.
The concept exploits the magnetic properties of the atomic makeup of a material to determine the chemical properties. Known as nuclear magnetic resonance, the process can give detailed information on the structure, dynamics, reaction states, chemical environment, and frequency characteristics. In this case, they looked at the magnetic properties of different tomato pastes.
They call the method, the "Magnetic Tongue." The researchers used the process on eighteen different tomato products along side several human testers. The Magnetic Tongue analyzed the smell and taste, with the results comparing almost exactly in line with the human test group.
The team is now setting off to see if the Magnetic Tongue can be applied to other foods. Slowly, but surely, we erase the importance of the human touch.
Eavesdropper
    DAB over 14 years ago
    If they do not double check their results with real people, I suspect that the machine taste testing will eventually fail.
    I have seen statistical correlations used for a lot of years, but in each instance, they still need to be independently verified.  The same will be true for this technology.  Yes, it might enable them to do a wider range of detailed testing, but those results will only take them so far.
    As always, they need to "Trust but Verify" the machines results.
    Anything intended for use by humans had better be tested by humans.
    Just my opinion.
