Publications
Publications
Blog Military microwave cannon
  • Author Author: Eavesdropper
  • Date Created: 19 Apr 2011 6:42 PM Date Created
  • Views 809 views
  • dit
  • military
  • eavesdropper:dit
  • bae
  • weapon
  • microwave
Eavesdropper
Eavesdropper
19 Apr 2011
BAE Systems, a US Defense contractor, is now testing a High-Powered Microwave (HPM) weapon on sea fairing ships and targets. This device can be pointed at a target, or in the general direction of the target, and effectively knock out electronics in its cone of fire, within range. BAE states, "BAE Systems is developing the High-Powered Microwave (HPM) to provide a means to shut down small boat engines at tactically significant ranges."
BAE's manager of business development, John Perry, touts the worth of the HPM, "the value of the HPM would be its fan of radiation, displacing the need for accuracy, and knocking out up to 30 small boats at a time — allowing other weapons to take it from there. “If you can knock out 50-75% of the engines in a swarm, you can then concentrate on the remainder with lasers or kinetic [weapons]."
Not sure about the effects of the human beings shot with this weapons, but it most likely is not a good thing. Although it has been tested, the final shape and design has not been released. Future electromagnetic wars sounds a bit friendlier, and welcome, in my opinion.
Eavesdropper
    DAB over 15 years ago
    Hi E,
    The HPM effect on humans would only cause problems if they were irradiated for long periods of time or at very close ranges. Think about your microwave oven.  Stuff directly under the emitter cooks faster than stuff on the edges.
    It only takes a few seconds to fry the electronics unless they are very well shielded, though if it was a matter of life or death, HPM at close range could be very effective on a human.
    Thanks,
