Publications
Publications
Blog New circuit design uses light instead of electricity
  • Date Created: 28 Feb 2012 8:23 PM Date Created
  • Views 657 views
  • research
  • alternative_energy
  • test
  • industry
  • hmi
  • lighting
  • on_campus
  • light
  • light_computing
  • Design
  • prototyping
  • measurement
  • university
  • metatronics
28 Feb 2012
Metatronic states (via University of Pennsylvania)
New technology often leads to a shift in the way we all think about design. Engineers know this better than anyone, especially when it comes to circuit design. With that in mind, researchers from the University of Pennsylvania have built the first ‘lumped' optical circuit powered by light. Designed by Professor Nader Engheta at the University’s School of Engineering and Applied Science along with some of his students, the new ‘lumped’ optical circuit (a combination of different circuit elements i.e.: resistors, inductors and capacitors) uses nano-rods that replicate the function of these lumped elements. This in-turn makes the circuit open and close while only using optical (or light) wavelengths. Engheta and his team tested the new circuit technology (called metatronics) by lighting up the nano-rods with light waves situated in the mid-infrared range. According to Professor Engheta, The team found (after nine different combinations of lumped circuit elements) ‘that the optical voltage and current were altered by the optical resistor’. This means that the circuit can be changed depending on the light wavelength being used almost instantaneously! Metatronics can do this because it is the elements that make up the circuit that are being manipulated, rather than the electric field
Professor Engheta spoke of the initial mindset that may open the door to innovation, "Looking at the success of electronics over the last century, I have always wondered why we should be limited to electric current in making circuits... If we moved to shorter wavelengths in the electromagnetic spectrum — like light — we could make things smaller, faster and more efficient.”
Cabe
http://twitter.com/Cabe_e14
    DAB over 14 years ago
    Hi Cabe,
    I like the post.  My observations indicate that photons are subatomic parts of electrons, so you should be able to move current or charge by the full electron energy or by the individual photon levels.  I look forward to their progress as they isolate the real transfer mechanics.
    I am not sure if you will actually see a speed increase.  The speed of light will still constrain the photon or charge transfer.  I agree that the circuit size will decrease as you use the higher frequencies, but you will probably still have propagation delays through the materials.
    You might see an overall speed increase if you use super conductors, but it will depend upon their transmission capability at the higher frequencies.
    Thanks
