Publications
Publications
Blog Projection-based folding tablet computers
  • Date Created: 6 Feb 2012 7:58 PM Date Created
  • Views 659 views
  • research
  • test
  • projection
  • mit
  • hmi
  • on_campus
  • embedded
  • Design
  • prototyping
  • interface
  • university
  • tablet
  • sensor
6 Feb 2012
Imagine being able to fit such a tablet into your pocket and not having to worry about reducing the size of the display.  It may soon be possible thanks to researcher Juergen Steimle. Working with faculty at MIT's media lab they have developed multiple tablets that work a bit differently than their traditional counterparts.
The technology, dubbed FoldMe, works by using infrared cameras overhead to track movement and position of the  tablet surface. The software interface is projected on to the surfaces, using two full high definition projectors to project the image onto the "tablet." Angle of the hinges within the tablet allowing the display to convert from a flat panel display, to a two panel display as if held like reading a book, or if folded completely over a smaller display.
Hand gestures can be read using infrared markers on the finger nails to give it the touch screen feel most people are used to. The hinges also create new controls that can be used within applications. Since the cameras read the angle of the fold, the angle can be used to control information that normally an on-screen dial would control.
It appears that this may not work well outside, or off the tablet projection grid. However, this may usher in a new level of connectivity for the boardroom. Later this month, Steimle will present his work at the TEI conference in Canada.
Cabe
http://twitter.com/Cabe_e14
  • Catwell
    Catwell over 14 years ago in reply to DAB
    I do like the idea of calling up the display of your computer anywhere. Pull it into a hand held form, pick a video, then display the film on a wall.
    In an enclosed environment, this sounds powerful.
    Cabe
    DAB over 14 years ago
    Hi Cabe,
    It looks like they need to work on the contrast, but it clearly shows we have the technology to implement these types of devices.  No magic, just some work needed on the implementation.
    Good post.
