Publications
Publications
Blog TinkerForge: Making Electronics Easy for a Wider Audience
  • Author Author: Eavesdropper
  • Date Created: 22 Dec 2011 7:15 PM Date Created
  • Views 635 views
  • test
  • hmi
  • microcontrollers
  • embedded
  • Design
  • prototyping
  • eavesdropper
  • tinkerforge
  • engineering
  • electronic_products
  • sensor
Eavesdropper
Eavesdropper
22 Dec 2011
There are many companies trying to bring robotics into the mainstream by making them cheap, providing expansive open source, easy-to-learn software and illustrating their immense range of capabilities. German company, TinkerForge, truly stands out in this sector bringing a high degree of adaptable and diverse hardware is.
In the past year, TinkerForge has released a new way of making their robotics hardware easy to upgrade, modify and learn about. Bricks and Bricklets are what they call small, 1.57’’ x 1.57’’, modular circuit boards that users can simply stack on one another to expand and explore new capabilities.
At the foundation of every stack, there is a base Brick, equipped with a 32bit microcontroller, two status LED’s, a USB port, and connectors to stack up to four specialized Bricklets atop.
Examples of some TinkerForge Bricks are:
● Master Brick used to communicate signals between Bricklets
● IMU Brick that process complex sensor information
● DC Brick that drive motors
● Servo Brick capable of controlling up to 7 RC servos
In addition to these base Bricks, TinkerForge has a wide variety of Bricklets that perform specific tasks. Infrared distance sensors, temperature sensors, humidity sensors are just a few examples. Control Bricklets, like joysticks and linear or rotating potentiometers, are also available. TinkerForge even has small LCD screens, monitor outputs, and more. The easy-to-use software treats the Brick and Bricklets as individually controlled circuits for easier programming.
The Bricks range from about $15 to $60 and Bricklets from $4 to $25. They come with beginner friendly, PC compatible software but are also programmable using coding languages such as C, C++, C#, Java and Python. TinkerForge also makes project source code and design files, along with many other resources, available on their website tinkerforge.com.
I am sure TinkerForge wants to take a piece of the Arduino market. Do they have a chance to catch up?
Eavesdropper
  • Eavesdropper
    Eavesdropper over 14 years ago in reply to DAB
    This is a great way to try out electronics development. However, most engineers have to build such systems from scratch.
    I'd like to sell a kit with a bag of parts that are not labelled, not what the user needs, with vague design requirements to give the "real engineering experience."
    E
    DAB over 14 years ago
    Hi E,
    I love this concept, Mechatronic tinker toys for people of all ages.  It would really be nice if these guys would integrate their products with robotsee or Windows Robotics SDK, but it looks like they have put together a simple enough system to do the job.
    This approach may well help spur the imagination of engineers of the future.
    My hat is off to these guys, it looks like a very well done tool set.
