Member and Staff Blogs Biosensor Array Update
  • Date Created: 26 Apr 2011 4:42 AM Date Created
  • Views 866 views
  • hackerspace
  • maker
  • body
  • education
  • pumpingstationone
  • hackerspaces
  • ps1
  • make
  • diy
  • chicago
  • ekg
  • gghc
  • biology
  • ecg
  • psone
e14 Contributor
e14 Contributor
26 Apr 2011
Greetings,
Here is a quick update on last week's activity on our Biosensor Array project for the GGHC. During our meeting on Saturday (Bill, Drew and myself), we performed the first integrated tests of 2 sensors connected to the same board (EKG and CO2), and we noted good results.
     Dan playing biosensor guinea pig at Pumping Station: One on Saturday
This is an update from our side:
  • We have a functional EKG sensor that I am moving to a proto board
  • Bill has a functional CO2 sensor mounted on a respirator mask with a fan for flow rate detection (as describe in his previous posts)
  • Shawn's temperature sensor works as intended
  • Drew creating new finger cuffs to decrease false positive events from the GSR (galvanic skin response) sensor
  • Oximetry sensor is still work progress
EKG and CO2 signals visualized in one of the OpenEEG programs, Electric Guru:
The heart of the EKG sensor is an instrumentation amp (INA114) which amplifies the small voltage difference between chest probes.  This type of amp is very good at eliminating the common mode signal the probes share which is predominantly 60Hz from AC power everywhere in the building:
Regards,
Dan
    e14 Contributor over 15 years ago
    I have that same co2 sensor and have had a heck of a time finding example sketches for interfacing it with the arduino.  Do you have any code you could post or send me via email?  Excellent work on the whole project as well you guys.
    e14 Contributor over 15 years ago in reply to e14 Contributor
    Desee, We used a modified version of the Parallax CO2 sensor.  Please check our Wiki and our Google discussion list for code details, we read the analog input and used a protocol compatible with the OpenEEG project (code is posted on mailing list and/or Github repository):
    http://wiki.pumpingstationone.org/index.php/Biosensor_Array#PS:1.27s_Element14_Blog
    http://groups.google.com/group/pumping-station-one-gghc
    Dan
