Member and Staff Blogs Monitoring Bees in Oregon 2025
  • Author Author: ralphjy
  • Date Created: 12 Apr 2025 9:06 PM Date Created
  • Views 5234 views
  • Likes 10 likes
  • Comments 88 comments
  • mason bees
  • honey bees
  • savethebeesch
ralphjy
ralphjy
12 Apr 2025
I posted earlier about putting out my mason bee houses.  I haven't been very successful with bees nesting the last couple of years so I thought this year that I would put up a camera to monitor the activity at the bee house.  I did a couple of small AI camera projects on Hackster last year so my first thought was that I would try to use one of those to detect bee activity.  The first project was the Dual AI Camera that used a Seeed Grove Vision AI V2 and Xiao ESP32S3 Sense for hummingbird detection and the second was the RPi Zero W Person Sensor Testbed which used an RPi AI Camera with an RPi Zero 2 W for Person Sensor testing.  In either case it would require training and deploying an appropriate model for bee detection.  The other major issue is that it is still raining here quite a lot and neither of these projects is weatherproof so I would need to build waterproof housings.
In the short term I decided that I would deploy a TP-Link Tapo C121 Security Camera that I have.  This is a nice compact and inexpensive 2K IP camera and it is IP66 rated.  It has motion detection and free Smart AI Detection for people, pets, and vehicles.  It also allows for RTSP streaming and local SD storage so that I won't need to access the cloud for recording.  I won't be able to do bee detection (unless I try to deploy a model on Frigate) but for now I'll try to see how it goes just trying to use motion detection.  Hopefully longer term I'll be able to deploy a solar powered dedicated AI camera with a mason bee detection model.
I mounted the camera on a metal garden pole that I used in a previous challenge.  The camera has a magnetic baseplate so it snapped right onto the top flange on the pole.  I tried not to put the camera too close to the bee house so I wouldn't disturb the bees.  I also turned off the visible and IR LEDs and the status LED.
Unfortunately, I haven't been able to identify mason bees in either the front or back yard yet.  I think when it gets sunnier I'll have more opportunities to see them at rest.  The closest I've gotten so far is that I saw a native bee on a leaf in the front yard but because its wings weren't deployed I couldn't get a clear view of the body to identify it.  Definitely a bee because of the distinct antennae.
After looking at a couple of detection captures I realized that it may be difficult to reliably identify mason bees vs other insects with the resolution and distance that I'm using.  Here's one where I drew a box around a bug on the right edge of the house.  Not enough resolution to get a clear image even if I zoom in.
I did see something I thought was a bee on the camera and went out to take some pics with my iPhone.
But with a zoomed in view it is clearly a housefly.
I tried limiting the motion detection zones but the camera is still detecting activity (mostly squirrels) along the top of the fence.
The captured video does not contain the bounding boxes so I need to do a screencap to show them.
I was dismayed to see that a bird showed up looking for a meal.  I wonder if he's gotten any bees.  I guess I'm going to have to put up some sort of screen...
Massive loss of bee colonies in Oregon
Local news stations are reporting large losses in honey bee hives (60%-75%) in Oregon in 2025.  Quite worrisome for agriculture in the state.
I am mostly focused on native bees currently but I do watch a community honey bee hive that the dogs and I encounter on our walks.  That hive wintered very well.  It had been downsized to just the brood box and a feeder.  In mid-spring I saw that they had added a super and last week there was lots of activity.  Thankfully that hive is doing well.  It bodes well for the nearby wild blackberries this summer.
    beacon_dave over 1 year ago in reply to beacon_dave +1
    Let's show them how it's done little buddy...
    Back for a late lunch I've been trying to get one that shows off the enormous proboscis but it is proving rather tricky...
    beacon_dave over 1 year ago in reply to ralphjy +1
    A mystery I wonder what it could ?
    "...Looking forward to seeing pics of your beebox..." Front view Entrance detail Top down view Top down view of base Underside of base Underside of top dome cover Info sheet…
    Close-up view of the exit
    View of the inside of the dome cover showing the exit
    I appear to have missed getting a photo of that.
    I've found them nesting in my compost bin, in an air brick and in the neighbours flat roof. Most appear to be passing through however so not sure where from. They can be hard to follow - you think they are heading off South and then a few seconds later they turn around and head North.
    It was fairly easy to find the compost bin one as there were about 50+ male tree bumblebees doing 'nest surveillance' attempting to get lucky with a resident queen. Sort of gives the secret location away a bit. Slight smile
    That's the second comment about squirrels nesting in solar panels I've heard this week.
    Perhaps something like a Docapole with a GoPro mounted on top might save the ol' legs ?
    Sunbathing - perhaps that was a crash landing after it had slid off the solar panel and trying to look cool...
  • ralphjy
    ralphjy over 1 year ago in reply to beacon_dave
    Ok, that makes sense.  I didn't pick up that the holes were the same shape but reversed direction.
    I should try to see if I can locate where the bees are nesting.
    On a side note I think I may have a problem with squirrels trying to nest in my solar panels.  I would think that they would get cooked by the heat.  Neighbor has a window with a good view of the panels and saw one spending a lot of time on the supports.  I've gotten too old to go up on the roof and do an inspection so I need to get someone do it for me (too steep a pitch for these old legs).  I laughed this morning when I saw one laying flat on its belly sunbathing on the top rail of my back fence.  May have to start eating them to reduce the population Laughing.
    I guess that they didn't think that the majority of the sales to the public would use it. Apparently as of this morning, they have had 27 people interested in buying one.
    If you look closely at the inside of the dome there is now a 'false ceiling', presumably for insulation purposes. It's conical on the inside, dome on the outside.
    I recall that they mentioned redesigning the entrance as the bees were plugging up the original design with grass.
    V2 & V3
    "...and some parts of the design didn’t quite fit the bees’ needs, such as entrance holes that bees had to block with grass..."
    V4
    "...The new design had better insulation, more effective temperature regulation, and improved entrance features..."
    I noticed with the bees nesting in my air brick, the bees exited from a different hole than the one the entered from (avoids a collision at peak times perhaps) so I'm guessing the larger shaped hole allows room for deploying wings during take off. It's the same arrangement on the inside, round hole transitioning to a D shape hole.
  • ralphjy
    Thanks for the pics.  I was a bit disappointed that they didn't leave the mounting structure for the infrared camera.  I'm interested to see they set that up.
    I haven't read the paper completely but did they explain the reason for that particular entrance design?
